I meant this is the only of the posts I could find right now, All I can tell you is I did come across the other posts I mentioned, but after extensive searching, I can't find them. The other two posts I remember were both positive regarding the DP500. I have never seen a negative review. If you are saying the DP500 is better than the Catclaw I believe you. Do you consider the DP500 II better than the TrusMT NF2?
LOL :-)
This is offtopic here.
Seems to be available for $85 now at http://dx.com/p/debao-iv-follow-focus-for-15mm-rod-black-red-blue-223873
