Nikon F to m43 adapters
  • The go-to shop for good adapters, ciecio7, unfortunately does not list a Nikon F to MFT adapter. I did send some questions, but unfortunately I did not receive any answer. Apparently they do exist, Grue has one, but I can't sit and wait for years to come. I did consider getting some Canon to MFT, but this leaves the issue of a solid Nikon to Canon adapter, preferably one which allows to change aperture by means of a ring or so. (There do exist adapters with a confirm chip, but with the Canon to MFT this won't work anyway.)
    Does somebody know another seller which offers the cheaper adapters, but has a solid check to deliver consistent adapters? I'd love to get an adapter with aperture control (manual of course) and a tripod mount.
  • 41 Replies sorted by
  • +1 to Metabones Nikon G -> m43
    Didn't know what I was missing! (my other 'no-name' mounts a pretty much lensbabys compared to this!)
    450 x 450 - 23K
  • @petersellersbuyers:
    As Vitaliy confirmed - Yes. The Nikon G to MFT "RJ Lens Turbo" adapter is also equipped with a stepless aperture control ring (mechanically pushing the aperture pin like the metabones speedbooster). So it´s usable with both of your lenses -> The 11-16mm and the 18-35mm (btw.: A nice set of lenses ^^).
  • in other terms, does it have an aperture ring that gradually pushes the mechanical system of the lens, like the metabones speedbooster? If it does, is it declicked?
    Yes, if you talk about Nikon G to m43 adapter :-)
  • Thank you for your explanation. About this RJ lens turbo, I've read the threads but couldn't get a straight conclusion about the following: will it let me change the aperture of the lens from f-stop to f-stop?in other terms, does it have an aperture ring that gradually pushes the mechanical system of the lens, like the metabones speedbooster? If it does, is it declicked? I'm sorry,I believe the answers must be somewhere in the threads on the subject, but I've spent all afternoon trying to figure this out. I found a bargain on the tokina 11-16 and also the sigma 18-35 1.8, so I must make a decision on the focal reducer.
  • Nikon AF and Nikon APS-C is the same (according the AT-X Pro 11-16mm F2.8 Tokina). It´s btw. a "DX" lens. So calculated for the APS-C sized sensors. Nikon F is the general mount. For manual AND autofocus (AF) lenses. Nikon F is btw. also used for the full frame system / lenses (so no difference like with Canon EF and EF-S for example).
    Nikon G to micro 4/3 speed booster (from metabones) should work. BUT if I remember right, it´s not the best image @ full open aperture. So it´s also ok, if you go with a normal standard adapter only (without any focal reducing optics). Btw.: You can also try out the way cheaper RJ lens turbo focal reducer (you can get it here in the forum in the VK-Deals quite cheap). The optics are not as good as the metabones. But it seems usable with the 11-16mm F2.8 (slightly stopped down) - And it´s WAY cheaper than the metabones version.
    About the size of the lens: APS-C is ok for the focal reducer (both - Metabones AND RJ lens turbo - on micro 4/3). And also full frame lenses are working flawlessly. You just need full frame lenses on (for example) the Nikon G to Sony E mount adapters, because Sony is using a APS-C sensor (which is way bigger than the Micro 4/3 one of your GH3 - So you need lenses with a bigger image circle to match the Sony APS-C sensor size ^^ - I hope it´s clear what I am meaning.).
    For more information on the RJ lens turbo check out the thread here in the forum ^^. There is also a video with the 11-16mm in Lucas Pfaffs channel (just watch the full video - The 11-16mm is visible btw. at 9:45 - But better watch it completely):
  • Hi, i have a doubt, maybe someone can help? There are two nikon versions of the Tokina AT-X PRO 11-16mm F2.8 DX: Nikon AF mount and Nikon APS-C. I wish to use the Nikon AF mount version on the gh3 (because I found a good business). Which adapter must I get,among the Metabones list? Will the Nikon G/m43 speedbooster work? Woud there be any difference for the APS-C version in the choosing of the adapter, or it's the same adapter? It's probably a dumb question,since I've been reading lots of threads and can't find any such doubt. thanks
  • I use the Voigtlander Nikon F to m4/3 adaptor. Smooth as yoghurt
  • Hi guys I came to this options someone help me choosing, best quality/price relation.
    /$85 Kipon Nikon G Mount Lens to Micro 4/3 Body Adapter http://www.amazon.com/Kipon-Nikon-Mount-Micro-Adapter/dp/B00596RO90/ref=sr_1_1?ie=UTF8&qid=1384016032&sr=8-1&keywords=Kipon+Nikon+Mount+to+Micro+4%2F3+Body+Adapter
    /$70 Fotodiox Pro Lens Mount Adapter, Nikon (G) Lens to MFT Micro 4/3 http://www.amazon.com/Fotodiox-Adapter-cameras-Panasonic-AG-AF100/dp/B008GVC2LK/ref=cm_cr_pr_pb_i
    /$23 Rainbowimaging Nikon G lens to Micro 4/3 adapter Aperture Control http://www.ebay.com/itm/Nikon-G-lens-to-Micro-4-3-adapter-Aperture-Control-GF2-/220773662886
    Don't recommend METABONES/NOVOFLEX/VOIGTLANDER I wont pay more than $90 for now.
    And any comments on the Vizelex Light Cannon from Fotodiox Pro markII or the mitakon?
    Thanks All
  • Well - A infinity adjustment would be great yes. Too bad that it´s not a standard feature =/ ... About the big_is adapters: I don´t know what they´ve done to their shop. But I cannot see any of the adapters with my standard browser. I only see it with a browser, where I am not logged in (to my Ebay account). Maybe they limited the possible countries (unwanted). Who knows.
    Here are the Nikon adapters of big_is:
    http://www.ebay.com/sch/m.html?_odkw=&_osacat=0&_armrs=1&_ssn=big_is&_trksid=p2046732.m570.l1313.TR0.TRC0.XNikon.TRS0&_nkw=Nikon&_sacat=0&_from=R40
  • @Tscheckoff thanks for the review. I find most inexpensive adapters require a new infinity adjustment. I looked on Big IS for the Nikon G to MFY adapter but couldn't find it. Let me know if you have a working link. Thanks.
  • Hmm. Maybe my (quick and dirty) comparison below helps someone. It´s a bit long (like all of my reviews / comparisons), but also shows a cheap alternative to the Novoflex (-> the Big-Is adapters). So check them out if you are searching for a cheaper option. ^^
  • I love my Novoflex Nikon to MFT adapter! It's worth every penny!
  • Got my Novoflex today and boy was it worth the extra money! Rock solid and perfect focus to infinity compared to my first El Cheapo adapter from Ebayland. Those who buy cheap buy twice!
  • They work the same as all other adapters with an aperture ring. Not sure what you are doing there?
  • @theconformist @tinyrobot I have two Novoflex Nikon to MFT adapters, and both let me use the aperture ring on my lenses that have them. You have to set the Novoflex to the fully closed position. (Towards the smaller circle.) They might be expensive, but the quality is superb.
  • @theconformist I didn't know the Novoflex didn't have an open setting so you could manually control the aperture directly on the lens. Bummer.
    Anyone use the Voigtlander adapter? Should be snug as they make quality products.
  • I bought an F mount to MFT adapter from Rainbow Imaging on ebay.
    It works well with an old 50mm 1.8 series E lens.
  • I use the Novolfex - expensive but the thing is snug and it's a tank. It has aperture control but this is actually a problem for me with lenses with a manual aperture - does anyone know a way to set it where I can control the aperture via the lens rings and not the adapter? It's a pain not knowing what f-stop I'm at.
  • I bought the Metabones adapter and it is a 'rock solid' adapter but it didn't allow my lenses to hit Infinity. I asked the seller why this was and he replied saying that they tune the adapter for still photography lenses or some bull to hit infinity earlier. My minimum focus was correct but I suspect the longer distances were off. So his solution was to send me various small paper rings that you put behind the lens mount of the adapter to adjust the focal flange relationship to get it to hit infinity on the lens. My adapter has some loseness now that I have done this adjustment and still doesn't hit infinity :/ should've just let it be.
  • i tried a novoflex that a friend had briefly. it was nice but 265 is too high for me...my lenses are ai and ais manual nikons.
  • Yes, Novoflex or Metabones if using manual nikons?The cheap Chinese adapters have some play and I'm looking to upgrade to a rock solid adapter.
  • anyone using metabones adapter? im curious how it fares in comparison with fotodiox.
  • @SightfulProd if you have a Nikon lens test it out. Close the aperture to the minimum it can go. Look at the back of the lens. There is a small metal lug or pin. Try to move it. It should be easy to move. This controls aperture. It snaps back to minimum aperture once you release it. Slide it and it opens up..
  • @SightfulProd no. It's the same. You are still using the lens mechanical iris. The adapter doesn't have it's own iris. It just controls the lens iris using the small metal lug which you find in the Nikon lens rear.
  • If you adjust aperture using the adapter instead of the lens Iris does it perform differently in how much depth of field is available?
