oscillian - is this halo visable in camera on the rear screen when you view the footage - or is it something that has been induced onto he image in post due to processing in Premiere
try trouble shooting this to see where the issue is occuring
I had an issue with my G6 it had a dead pixel cluster on the sensor so its had to be returned for a replacement new body - Im now awaiting this to arrive
First off: this is probably a hardware error:
Dark halo-ing on the left(?) of bright objects!
UPDATE! This is caused by i.Dynamic settings. Turn OFF to avoid these artifacts!
AVCHD 50p ISO 160 Shutter 1/50 Photo Style: Natural: -5,0,0,-5 WB: Cloudy First clip: Olympus 45mm f1.8 @f1.8 Second clip: Lumix 14-140mm, 14mm@ f4
MPEG 50p export straight from Premiere
