5dtoRGB and GH3 transcoding
  • I just purchazed 5dtoRGB Batch version of the software and wanted to transcode some IPB .MOV files form my GH3 camera. I used Full Range Luminance setting (screenshot attached). However, the resulting file is identical to the original .MOV file. I thought I was supposed to get a "flatter" image with some recovered highlights, perhaps? In fact, I might be wrong, but the resulting file has ever so slightly increased contrast. It's almost imperceptible and I might be wrong. I'll try to add screenshots to this posting.
    In any case, I don't see any changes in the new transcoded file.
    I also ran some MTS files from my hacked GH2 and the results are there! I get flat image from GH2 files, but not from GH3.
    Am I doing something wrong?
    Thank you all in advance.
  • 35 Replies sorted by
  • I'm attaching the screenshots of the original and transcoded 422HQ files.
    1719 x 977 - 3M
    1745 x 988 - 3M
  • These are screenshots of the original GH2 mts file and transcoded file. There is a huge difference. So, the software does give flatter image with GH2 but not with GH3.
    EDIT: I just noticed that I named the screenshots incorrectly. Files names should be reverse, but you can see the difference anyway: flatter image is the transcoded one.
    1749 x 969 - 3M
    1703 x 955 - 3M
  • You're not supposed to be transcoding to full range. There's a whole thread about this. These camera do not shoot full range so you are introducing noise and other factors that are not in the original footage.
  • Thanks. I've read many different posts all over the net so I'm a bit confused what's best. Some mention the benefits of full range other are against.
    I might go with Broadcast Range, just to be safe. But, I would still like to find out why GH3 files are not giving me flat image, like GH2. For my information, at least.
    Thanks again
  • Welcome. I'm by no means an expert but some really knowledgeable people ran many tests to show the true negative and positives on here. Search for the 5dtoRGB.thread and go though it. It's huge but you'll get to the good info.
  • In that thread, shian mentioned no difference with GH3 files.
  • Thank you!
  • @vicharris
    This is essentially not correct... the contrary… as long as you are referring to 5DtoRGB's setting called "fullrange".
    In 5DtoRGB the setting "fullrange" means: "preserve the full luminance levels contained in the source file". In other words: "do not remap luminance levels".
    When the source file contains fullswing levels 5DtoRGB's setting "fullrange" will output a file containing fullswing levels. When the source file contains studioswing levels 5DtoRGB's setting "fullswing" will do exactly the same - it preserves the full range of luminance levels contained in the source file. BUT: studioswing utilzes luminance levels from 16-235 (8bit naming) for image content. However, broadcast-safe colors ("studioswing") also contain luminance levels from 0-15 and 236-255. These levels are not utilized for image content but are preserved for footroom and headroom (so while not utilized for image content these levels are still present in the file - note that Rec709 technically always contains 0-255 luminance levels).
    Therefore 5DtoRGB's setting "fullrange" essentially will output files from the GH2 and the GH3 that look "dull" on a computer screen when viewed in appropriate software (but they look absolutely correct on a TV-screen). Of course, if you transcode to ProRes-QT the files contain tags assigned for viewing purposes on a computer screen - in effect the files look like "fullswing" in Quicktime (also in the interface of most other video-viewing-softwares designed for computers… for instance VLC, Movist etc. - and AFAIK this applies also to FCP7 / FCPx since these softwares are based on Quicktime). But this is just an "issue" of the respective viewing-softwares. When you view the respective files in a professional video editing software and open the Y-waveform-monitor you will see that the actual image content lives within 16-235 (see attachments).
    So... again: using the "fullrange" setting in 5DtoRGB will preserve the full range of luminance levels contained in the source file!
    In other words: this (and only this) setting will achieve a "lossless" transcode to ProRes.
    You can remap broadcast safe levels from 16-235 to 0-255 when you set the setting to "broadcast". But the transcode remaps in 10bit. I feel much better to preserve the luminance levels of the source files and remap to fullswing (or whatever...) in the editing software in 16bit (or 32bit). Therefore I always set 5DtoRGB to "fullrange" (= "preserve the original luminance levels of the source file" = "no remapping").
    1920 x 1200 - 794K
    1920 x 471 - 520K
  • So that whole long thread of Shian as well as other testing this theory for months is wrong? This is what you are saying, right? I just want to be clear because this is getting absurd.
  • @vicharris
    can you give me a pointer to the respective thread ... I don't know it.
    Thanks in advance!
  • Thanks @towi
    I have been transcoding my GH2 files as BT.709 "broadcast range" most of the time. So I was basically not gaining but also not losing any information, except for leaving to 5DtoRGB to remap 16-235 to 0-255 in 10bit space.. Is that right?
  • @inqb8tr
    yes, that's absolutely correct!
    In most cases 10bit is totally fine. Really! Only in very rare cases (especially when you lift the shadows in post) it is preferable not to remap in 10bit (through 5DtoRGB) but to preserve the original luminance levels on transcode and then apply a curve in the NLE in 16 (or higher) bit. Since I don't want to dig too deep into the actual footage in my workflow I always transcode/import everything without remapping and apply high bit curves in the NLE afterwards. But this is just a matter of workflow standarization ... which I personally am finding easier to manage.
  • @vicharris
    well, I did a quick research and found some posts of "shian" on the topic. Since he uses FCP everything is fine with regard to his particular workflow. Nevertheless in 5DtoRGB the setting "broadcast" remaps studioswing to fullswing (16-235 to 0255)... which is a pretty trouble-free workflow for the QT-based FCP applications. However, technically speaking there is a remapping going on ... and this remapping is in 10bit. 5DtoRGBs setting "fullrange" doesn't remap at all. It passes the "full range range of luminance levels contained in the source file" to the outputted file. That's all I am talking about ... And, sorry, this is not "absurd", it's simply what's going on technically ...
  • @towi I didn't mean the explanation you gave was absurd, just the fact this can't be decided on, that's all. It wasn't a swipe at you by any means. So is this statement not true?
    "if you do a test, which i did earlier in this thread, you can see that full range is actually just lifting your shadows and compressing your highlights. The cam records in broadcast. So you are actually baking a shadow lift and highlight compression into your footage. And 601 does some odd stuff too."
  • @vicharris
    No, it's not true... except of the note the cam records broadcast levels.
    you can see that full range is actually just lifting your shadows and compressing your highlights. (...) So you are actually baking a shadow lift and highlight compression into your footage
    The other way around! The camera records "broadcast safe" 16-235 levels ... so if you want so, it records "lifted" shadows and "compressed" highlights (in fact nothing is lifted or compressed... but it looks flat on a computer screen). So when you set 5DtoRGB to "broadcast" you are baking an expanded luminance range into your footage. "Fullrange" passes the full range of luminance levels contained in the source file into the transcoded footage.
    As far as the GH3 goes the QT files contain meta data showing the colors/levels utilized ... the GH2's MTS files do not contain these tags (see attachment).
    499 x 608 - 138K
  • Everything is Quite confusing :)
  • Since I need to match the files I shot on both GH3 and GH2, I opted for transcoding with Broadcast Range. They both look similar to my eye right away. When I transcoded with Full Range, Gh2 files looked "flat" and GH3 files didn't change at all. That would create more work for me in the post since I have to do extra work to math them.
  • @mastroiani
    this may make things a bit more clear: http://www.belle-nuit.com/test-chart
    In addition here's also a chart containing only broadcast safe colors: http://www.file-upload.net/download-7791434/HD_Testchart.tif.html
  • @Shian Sorry to get you involved in this again but maybe you can chime in here? If not, I completely understand since this has already been beat to death before.
  • sigh It's getting to the point where I don't even care anymore. Do whatever the hell you feel like doing. BUT
    There is zero difference between 5DtoRGB, 709, "Broadcast" ProRes 422 HQ transcodes and FCP7 and FCPX ProRes 422 HQ transcodes. None.
    "Full Range" actually stretches the luma out. But there is zero difference in quality between transcoding full in 5DtoRGB and manually taking footage transcoded at "Broadcast" and stretching the Luma out in post. None. Not on a WFM and not to the eye.
    So whether the computer does it, or you do it manually. The result is the same.
    Now with 4444 footage I did some serious pixel peeping in my test and could see very slight, and I mean infinitesimal amounts of color distortion on FCP and 5DtoRGB broadcast footage when zoomed at 400% versus when using full range 4444 transcodes which showed no distortion. I was bending the shit out of the image, farther than you ever would in any serious grade to get this distortion, and it is not noticeable to the naked eye at 100%. What you gain from transcoding full @ 4444 vs. broadcast @ 422 is not worth the extra drive space. And between 422 broadcast and Full is not even worth the amount of words I've poured into this post.
    In the end - it is all much ado about nothing. Today, I only use 5DtoRGB to transcode when for some reason FCP won't recognize my hacked footage.
  • Thanks @shian and sorry to be a pain in the ass! I'm putting this subject in a safe and sinking it to the bottom of the ocean.
  • No worries, Vic. I did these tests to save people time and energy, and in the end it accomplishes next to nothing. So I stopped doing them.
    I'm glad at least some people pay attention.
  • Something very disconcerting is happening with GH3 footage. I've been transcoding the footage with Broadcast Range thinking that there would be no change, but the resulting footage is a lot more contrasty than the original. This is really bad. Clearly 5dtoRGB is crushing blacks and making the image more contrasty...
    1920 x 1080 - 3M
    1920 x 1080 - 3M
  • More samples...
    I was hoping that at least 5dtoRGB wouldn't mess up my footage, but this is really bad.
    1570 x 992 - 2M
    1523 x 990 - 2M
  • if you are shooting quicktime movies in the cam, why the hell are you bothering to transcode them? Just start editing.
    5DtoRGB is really only for turning mts files into something we can edit.
