@xavieramelio, use the 720p60 H mode with your current card and you should be OK.
This is all Moon T5 with my Kowa anamorphic and Konica 40mm lens. I'll probably use it in the music visual for a song that I am writing.
http://www.flickr.com/photos/68917223@N05/sets/72157634273204895
@vicharris, @maddog15, @Zaven13, Thank you for the info, maybe was a problem of detail, I was out door with lots of sun and shooting at some houses with brick walls. I will keep on trying.
I just shoot a wedding video using Cluster X Series: 12/15 GOP - 'DREWnet' Trial 8 and it went perfect. Nice patch for long recordings thanks @driftwood !!!
@htf I am using 16BG Sandisk Extreme card. For me, 16GB is enough, I use many of 16GB rather than high capacity cards. I don't want to bet too much data on one card.
I am shooting a micro doc on a vintage car race (using Moon T5). Footage looks great, learning a lot in the process. Nikon 24 F2.8 glass mostly. Card sandisk is 32gb 95mb/s. Having learned a good bit from @shian on exposure, I feel I am starting to understand the need to light. Special thanks to @Vitaliy_Kiselev and @driftwood . Will share the finished piece next week.
iPhone photo-
@vicharris OOPS:) always had the impression that people just posted in the current Drift wood thread... I've reposteded to the senda thread
@treeclown Wrong topic. :) It should go in the Sedna thread, not the ClusterX, just so people don't get confused.
anybody else having trouble using the new PluralEyes3 (for windows) syncing audio with a hacked GH2? i've got a drewnet t8 hack and pluraleyes gives me a media error and won't do any syncing
it is a tricky beast, but i never head a problem with pluraleyes 2 with hacked gh2 footage, guess i'll go roll back
MOON T3, Smooth all -2.
I use the same and haven't had issues other than 720 60p stops recording at 15 minutes... so no spanning but who cares. That said....
A fresh reload of Moon T5 on your camera is where I'd start first.
If all else fails you might consider a full over rite reformat of the card. I've done this in the past when a card started to get "finicky." See what others suggest first as some feel you should never have to fully reformat the card.
NOTE: only use the official SD formater application on your PC for this. (The 64GB 95Mb/s card must be properly formatted as ExFAT.) This is specific to this particular SDXC card and different from all the other cards "beneath" the 95Mb/s card. The formater app is free to download.
Good luck.
@rayycy. I had your problem with both 720p60 SH and 1080i60 using Sandisk 64GB 95mbs. What I chose to do is use Moon T5 and change the quantizer to 16 instead of 14, change the high and low bitrates for 1080i/720p from FSH/SH=93 to 88 and FH/H=48 to 58. I also adjusted the bitrate limits to match the new numbers. Those changes eliminated the card write errors for me. Spanning is still an issue with FSH/SH but not with FH/H. Hope this helps.
@callan. My apologies. There was an error in my post. When @driftwood introduced, Moon T3 and T4, I heard the comments that T3 is too soft and T4 is too sharp. So what I did was to use T4 matrix and change the initial quantizer from 14 to 16 a long with bitrates I mentioned above. Moon T5 was released by @driftwood with similar changes & lower bitrates for stability. If you check Moon T4, you will find the numbers I posted earlier. Below are the original T4 and my version.
