Timelapse issue with hpx170
  • So i was in vegas few days ago and i filmed with my hpx170 out the window of the hotel hoping to get the Timelapse (light streaking) effect. I used 2FPS SCENE file and I set Shutter to 360*. Question is that right? and what do i then need to do in post to get it to look correct? i tried 700% and it doesnt look right.
  • 2 Replies sorted by
  • Do you have any video of your result?
    It is also not really camera specific thing, as 2fps and 0.5sec shutter an be used for timelapse on any camera.
  • No i didnt do it right, here is what i was told on dvxuser.
    "No, set the camera up like this. First be sure in Scene file you on "Video Cam" From the menu choose 5. Recording set up. 720P/30, then in record function (2 down on the menu) choose interval. You'll have a ton of options which is a real strong point of the this camera system. One entered, completely exit and you can use the shutter speed select to choose exposure time. It will be in parts of a second, the slowest is 1/15. "
