GH3 back from service, is now 60P instead of 50P?
  • Hi,
    I just got my GH3 back from service where they swapped the main board. The problem is that it now has NTSC framerates instead of the PAL framerates that I need. It also has some kind of service menu now called ROM BACKUP as you can see in the attached picture.
    It was returned with firmware 1.0 and I have upgraded to 1.1 without that making any difference.
    Is there any way to get it back to PAL framerates, or do I have to return it once more?
    Thanks!!
  • 3 Replies sorted by
  • Just pass it back to them.
  • Really? That will be 3-4 more weeks probably. Such a pain! Just curious, do you know what that ROM BACKUP menu is? It writes some txt files to the sd card with lots of hex code.
  • @AndersM
    It is service mode functions.
