@Jean didn't know about that video. It's clearly Kinect, but frankly I think they used it in a very basic and sterile way, don't you think? Ever seen this? http://www.rgbdtoolkit.com/ it's very interesting
@Oblikovalnik I've been playing around with Processing some years ago, but didn't do anything constructive with it. My background is electronic engineering so I'm quite comfortable with learning some programming language. Sometime I fancy buying an Arduino board but I'm already too busy, should I start tripping with interaction, I fear I would never leave this keyboard! Greetings from Trst!
@flablo this was great man, have you been doing anything with Processing as well? Greets from Ljubljana.
Franco Battiato's (Italian singer) video made with Kinect.
http://m.vevo.com/watch/franco-battiato/quandero-giovane/ITUV71300078?playonmobile=true
@peternap thank you! Basically I used the Kinect to capture the movement of the boxer. I captured clips of data at 30 fps like a video, but instead of the image for every frame I recorded the scan of the points in 3d space, then I could use those however I wanted in a 3D application. I associated them to the cards and I could move the camera as I wished. Resolution was low but enough to give the idea of the shape.
skip directly to 2:08 because first part is a boring intro. The boxers (actually he is ONE, a friend of mine) are made with Kinect capture, using the code made by these cool guys http://moullinex.tumblr.com/post/3180520798/catalina-music-video. It uses Processing to capture the data. And the data files of point clouds are really huge
Do you have result video?
That's impressive. There seems to be still some minor delay between real action and feedback from the Kinect, which in my opinion was one of the drawbacks of the original. I used it to record point cloud sequences (like a 3d-scan video) and used them with particle systems in Cinema4D to make a video. And it was definitely fun.
