Benro monopods have a fluid cartridge in the base seeing as the heads pan unlike the Manfrotto
What you mean? All fluid action is happening in the head, and different heads are supplied with different monopods.
Does anyone know if the Benro monopods have a fluid cartridge in the base seeing as the heads pan unlike the Manfrotto?
I really like the Benro monopod with the flip locks (like manfrotto) instead of the twist locks for faster height adjustment. The first versions only seemed to have the twist locks. Might be time to pull the trigger on one of these as they seem much cheaper for similar quality to the manfrotto 561HDV
Do we know if the Benro is also aluminum?
Ones referenced are alu, here is carbon ones
Wish someone would make a monopod that could be locked in the upright and be able to work a small 60cm slider. Am I asking for too much? ..............Yeah probably I am.
