Hi there,
if this question was already anwered somewhere else ... please forgive me :)
Is there any way to tweak the AGC - value on the Panasonic G2? Or is there even a way to disable AGC completely?
I use a Zoom H1 with a DIY-AttenuatorCable on my G2 and the sound could be alright if there wasn't this noise during silence due to AGC ... Any help would be mostly appreciated :)
Doing a little bit more research I found this solution: http://www.learningdslrvideo.com/t2i-7d-disable-agc-rode-videomic/
... but I guess wasting one stereo channel just to get rid of the AGC isn't optimal as well ... maybe there is some other way to turn AGC off, without using PTool? Perhaps some value in the .bin-file you could change manually ... ? Probably not ... ?
Because it is so much work to get it all synced in post
All you really need is proper software.
Check PluralEyes or Magix or other editors.
As for AGC, I think no one will disable it. It is better get new camera.
Because it is so much work to get it all synced in post. Currently I use the G2 to do some kind of a documentary project, where I need to act pretty fast ... so can't always get in front of the camera an do a handclap ... also, when I'm in a hurry I tend to forget to push the record-button on the Zoom.
Now, I'm looking for a way to get the best possible in-camera record setup
If you use Zoom why you are worried about G2 sound? Why not to use sound recorded on Zoom?
