hello, i´m having trouble with this recorder, i´m using an external mic (ntg-2) along an "M-audio firewire" solo as a preamp,
the noise appears only when recording, not on the pre rec stage (where we can hear the input mic), it always starts with something that reminds me the noise of a cd rom entering the pc, and then it gets periodic, like a brum, brum, brum... the noise changes the priodicy if i change the recording hz, at 96 is faster, at 48hz is slower, mono or stereo recording makes no difference.
the noise also is only noticeable when there is silence, if there is an ambient noise sometimes is not noticeable, it is there though...
any one knows how to solve this?? i believe it´s hardware related problem, but i think is coming from the tascam and not the "firewire solo" or the mic
For the DR40 w/ your FW Solo, you would use 1/4in balanced cable on both ends (I believe you only need to connect one of these outputs to the recorder since the mic is mono, and record in mono). DR05 with a lavalier mic should work fine. I have not experienced the helicopter issue, so can't comment on that.
i was actually thinking of getting a dr-40, but i was reading that they have a sort of helicopter issue?, i thought it was the same problem i was having,
what cable should i buy from the FW solo stereo 1/4 jack to the Tascam dr-40? and also if i buy the dr-40 i was thinking of using the tascam dr05 with a lavalier mic (that i don´t have yet), do you think that should get rid of the problem also?
well, sounds like you have to rule out the Tascam then. Get hold of a different recorder (same type of input, but different brand or model) and see if the noise disappears. Just a note: I've had success connecting balanced line output from a pro mixing board into a Tascam DR40....a recorder like the DR40 is more suited for your setup, in my humble opinion.
i think the cable is fine, because is only when recording that the noise comes out, the tascam has an option of listening the input before the actual record, but when i listen from there the audio is really clean, is only when it starts recording on the card that the trouble comes out, and as i said i tried other cable but the noise is still there
I wonder if your custom cable was wired correctly. Also, there is a chance that the Tascam input is a mini-balanced input, which would be good. But if it's not, then you're faced with having to connect a balanced output to an unbalanced input....this complicates things slightly. Maybe a trip to your nearest audio specialty store is in order, you might have to try out different cables to find something that works.
basically, if you don't hear the noise when listening on headphones from the FW Solo, it must be the connection to the Tascam. The custom cable should be balanced (have two black rings like a stereo connector vs. one ring mono) going out from the balanced line output into the Tascam. If there's still noise, it's probably because the Tascam input isn't balanced.
the setup is: mic Rode ntg2>xlr cable (i´m using the Rode xlr cable male to female that comes with the Rode blimp is a 1 foot long cable)>M audio Firewire solo powering phantom to the mic> the cable described up above (i have tried all the outputs (it has 4)and they dont make any difference)>Tascam dr 05
here is a link to the noise audio, perhaps someone would recognize the issue: http://vocaroo.com/i/s0UUM6yXtdBk
I remember having an issue like that once with the M-Audio Microtrack II, but I seem to remember it came down to the device having some issues with unbalanced vs balanced cables. Might be worth trying swapping them out to see if it makes a difference.
