I came across a post from Alex4D suggesting imovie2013 & FCPX10.1 share the same software/code which gives some insight in what we can expect in the new release: http://alex4d.com/notes/item/imovie-2013-is-consumer-ui-on-fcpx
Really? What camera and what shutter speed did you shoot at?
When conforming a 50p video in Final cut pro X (10.0.8) to 23,976 in a 23,976 sequence for nice slow motion, FCPX doubles a frame every second!
Well that would be pretty awesome since it's already so fucking good.
My feeling is to temper high expectations. Expect one major new feature, a couple of minor features, and lots of bug fixes.
The forums I've been on are expecting major, but not another complete overhaul. It's the 1.0 release, and Mavericks and the new MacPro are coming, too. Of course none of us really know, but I'd go with optimism at this point that we'll see a release to further bring FCPX into it's own. (Like 0.6 I believe it was.)
So the rumor mill on Twitter is suggesting there's a major FCPX update coming this week that will be a total rewrite from the ground up. Does anyone know if there have been more substantial reports of this anywhere? I can just imagine the protests if Apple decides to do another complete overhaul with zero input from the users, especially those who have adopted FCPX rather than jump ship for another NLE.
@B3Guy Not great at the moment using just FCPXML. However, if you use X2Pro to make an AAF, it's close to perfect. X2Pro has one li'l bug right now regarding subroles and multiclips (you have to send all clip components out to the AAF even if they are turned off in the timeline). X2Pro works fine with regular clips or synchronized clips.
With X2Pro and subroles, I was able to turn the unorganized file below... into the organized one.
How is integration with Logic X?
Just wrote a "little" blog post about a workaround for dealing with multi-channel audio and subroles in FCP X. http://www.garbershop.com/?p=391
@ahbleza @Conundrum Thanks! Glad you enjoyed it.
Excellent article!!! So many great tips and methods. I've just started finding the courage to use FCPX on pro projects and am beginning to see the potential of roles and compounding. As I change my perspective I'm starting to feel more comfortable with the new paradigm. Thanks for a clear and informative piece!!
Hey y'all. I wrote an article about editing broadcast news stories in X.
http://library.creativecow.net/garber_michael/FCPX-News-Editing/1
@shian agreed. i tried it for a few minutes. if the color grading was more useful, i could see some application for it. otherwise, it doesn't really save me any time.
I installed that ProCutX app and played with it, cuz it's free if you go through the app store on your iPad - it's alright... but not mind blowing... a lot of features don't work at all, or don't work well. The grading panel is useless. I'd have been pissed if I paid $25 for it. It's an ok companion device for X, but not what i was hoping for, which was a killer control surface.
@squig Now we get to be 10.0.8 crash test dummies. If it wasn't for the green frames I wouldn't risk it.
I've just been cutting for the past couple of days on a project using the new 10.0.8, and I have to say, this version of FCPX is much less crashy than all previous versions. There were times I did something that has felt like causing a crash in the past, but it just kept on going like a champ. I see no downside to upgrading at this stage.
FINALLY!
Awesome. 10.0.8 also fixes this crash i was getting constantly: https://discussions.apple.com/message/21601080#21601080
Final Cut Pro X version 10.0.8
This update improves overall stability, performance, and compatibility. Updates include:
Support for Sony XAVC codec up to 4K resolution
Option to display ProRes Log C files from ARRI ALEXA cameras with standard Rec. 709 color and contrast levels
Resolves an issue where some third-party effects generated green frames during render
Resolves performance issues that could occur with certain titles and effects
Time reversed clips render in the background
Ability to use key commands to adjust Clip Appearance settings in the timeline
Ability to view reel number metadata located in the timecode track of video files
Mono audio files in a surround project export with correct volume levels
Drop zones no longer reset to the first frame of video after application restart
Fixes a performance issue which resulted from selecting multiple ranges on a single clip
Fixes an issue where the Play Around function did not work properly on certain clips when viewed through external video devices
http://www.apple.com/uk/finalcutpro/whats-new/
http://support.apple.com/kb/HT4589
Motion 5.0.7
Fixes a stability issue when splitting layers in the timeline
Fixes an issue where launching a plug-in with a check box could require multiple clicks
Fixes a stability issue with CoreMelt plug-ins
This update is recommended for all users of Motion. For more information visit www.apple.com/finalcutpro/motion.
http://support.apple.com/kb/HT4591
Compressor 4 version 4.0.7
Removes 1 GB file size limit for uploads to Vimeo
Fixes a stability issue when playing back certain MPEG-2 files
Fixes a stability issue in Qmaster when processing multiple jobs
http://support.apple.com/kb/HT4590
ProApps QuickTime Codecs v1.0.2
This update adds the following video codecs for use by QuickTime-based applications:
Apple Intermediate Codec
Apple ProRes
AVC-Intra
DVCPRO HD
HDV
XDCAM HD / EX / HD422
MPEG IMX
Uncompressed 4:2:2
XAVC
This update is recommended for all users of Final Cut Pro X, Motion 5, or Compressor 4.
http://www.macupdate.com/download/39040/ProAppsQTCodecs1.0.2.dmg
FCPX runs only on OSX. I don't think I'd get another Macbook Pro. Too expensive. $2k $3k? I'd rather get a PC laptop little over $1k and upgrade from GH2 to GH5 (haha). OSX is nice, but I wouldn't miss much.
Apologies if this has been posted somewhere on here already, but I found these tutorials to be SUPER HELPFUL for the most part (I don't agree with him on using the global exposure adjustment for setting focus exposure) http://www.colorgradingcentral.com/final-cut-pro-x-color-grading-table-of-contents
