I like.
@labalbi they don't look stabilized at all. The over-crank helps to smooth out the handheld moves.
@beeldlab thanks Hugo. so very good. Your work inspires me and I want to try Kowa 8Z now :)
Thank you @pchristoph
Thanks @rockroadpix
@pind that's not a filter it's a lens.
Thanks @pind. And as @BurnetRhoades wrote, it's an anamorphic lens in front of a 'normal' lens.
Is the GH3 easier to grade than the GH2? How much room between both cameras?
@x_worpig_x I noticed the GH3 had a larger range to play around with color correction then GH2. Where GH2 falls apart. GH3 footage stays pretty when doing more intense color correcting.
@beeldlab Thanks! The video looks fantastic by the way. Where was this shot?
@beeldlab what codec are you using may i ask?
