@beeldlab what codec are you using may i ask?
@beeldlab Thanks! The video looks fantastic by the way. Where was this shot?
@x_worpig_x I noticed the GH3 had a larger range to play around with color correction then GH2. Where GH2 falls apart. GH3 footage stays pretty when doing more intense color correcting.
Is the GH3 easier to grade than the GH2? How much room between both cameras?
Thanks @pind. And as @BurnetRhoades wrote, it's an anamorphic lens in front of a 'normal' lens.
@pind that's not a filter it's a lens.
Thanks @rockroadpix
Thank you @pchristoph
@beeldlab thanks Hugo. so very good. Your work inspires me and I want to try Kowa 8Z now :)
@labalbi they don't look stabilized at all. The over-crank helps to smooth out the handheld moves.
I like.
