@JackBayer: I don't! I never did. I just lifted that possibility for those who use external power sources like @nomad mentioned.
But... my guess is that either the sensor or the h264 encoder must be a beast on power resources on regular usage, because IIRC when switching to 2fps, my batteries run for almost 4h. And it's no wonder... there's over 10x less data to move/compress.
Thanks.
Sorry for the delay, I'm sort of in between jobs and I haven't been following this thread closely.
@monoseba: This is a patch dedicated to getting the best IQ possible from timelapses. The documentation can help you (it's attached in the first post): http://www.personal-view.com/talks/uploads/FileUpload/23/28051c411a6358790a9008d1ec3e04.zip
@mityazabuben: When the expo is changing, you have three options:
a) You change the shutter speed to accommodate the light change, and if so you shouldn't be using this Timebuster patch because it is tailored to one specific shutter speed and will give you s**t if you use a different one.
b) You use a Variable ND filter and watch your histogram as the light is changing and adjust to changing light.
c) You do nothing of the previous and adjust later in post.
IMHO a) is the easiest, b) will get you the best IQ, c) should be your last resort.
So, you have met the famous trash frames. Those were totally bitrate starved on purpose. You need to weed them out from the good I-Frames! This might help: http://www.personal-view.com/talks/discussion/comment/49325#Comment_49325
@3dwint: timebuster by nature is very undemanding on the SD card speed, and I've targeted an extremely frugal set of parameters, and only on the modes it is supposed to use. Everything else was left untouched. If you are having speed errors, please test the merger patch (did you use the FlowMotion variant?) in the same conditions. Most likely the speed issue should be in Flowmotion as well. BTW, IIRC, 45MBs cards are known for causing speed issues, but Flowmotion is also known for being solid on Class 10 cards.
And no, you don't need to use the high bitrate Flowmotion variant. You can use the GH2 vanilla patch if you use timebuster/timeHBusteR Base version. Quality will drop though... noticeably.
@nomad: Thanks for dropping in.
Am I need to do it before processing in AE?
When I making TL in AE with the workflow explained here, Ive got some frames with artifacts (movement objects all in square, color artifacts - is this some P-frames with trash?). Any advice what am I doing wrong? Thanks.
Hi. Noob question - how does it work, when the expo is changing (sunset)? Any sort of bulb ramping?
@taipan Use the latest alpha, I think it's solved there: http://www.personal-view.com/talks/discussion/comment/79714#Comment_79714
It's your shutter speed. No menu option.
where is the 2fps option??? i cant find it is it in the menu??
I installed the Latest 30fps TImebuster HBR from the front page= Followed the rules in page 7 and everything seems to work.
But when I switch to Cinema Mode and record, upon playback it looks choppy and messed up. I thought the TimebusterHBR patch was supposed to leave the cinema mode alone?
@Stiffla: This latest patch has a much different implementation (I/P/B GOP) than 1.3 (which was I/P GOP exclusively) and as a consequence it is a lot less tolerant to bad frames in a way that you REALLY NEED too weed out the bad ones because starved B-Frames (unlike P-Frames) look really bad and to add insult to injury they twice as much in bitrate... :P
I've had other reports on the bitrate issue. I will try to investigate it, if only I can find the time...
@duartix I was wondering if you can help me or someone else maybe.
I used your timebuster 1.3 for my wall project last year in 24p mode and 1/2 shutter speed, everything worked fine. Now I'am trying to merge it with flowmotion 2.02, because I'm gonna use it as B-cam to my AG-AC90 for skateboarding purposes.
Now the result is that the picture is flickering and stuttering in all modes. I already tried your Timebuster 2.0 patch, but it's still not working and I think the bitrates in 24p 1/2 shutter speed are really high compared to those of the 1.3 patch.
I'm really not sure what I'm doing wrong in the merging process.
@zcream: If you mean video, then the answer is No. The slowest SS is 1/2s.
Is there a way to get long exposure i.e. 5-10sec exposure with any hack ?
@zcream :Follow the workflow for weeding out bad frames: http://www.personal-view.com/talks/discussion/comment/49325#Comment_49325 but before you do that you have to import the footage properly. Yesterday I had that very same interlacing problem and couldn't remember how to do it, but fortunately the internet forgets nothing: http://www.personal-view.com/talks/discussion/comment/57925#Comment_57925
