@QuickHitRecord Nice approach. I'll try. Thanks!
@aldolega According to Metabones, hopefully by the end of the year.
@Flaaandeeers It is tedious but worth it, especially for zoom lenses. At the risk of going off topic, here's what I do:
I remove the metal face of the adapter and layer four tiny pieces of clear Scotch tape underneath, and then put the adapter back together again. I use my locked down camera and tripod to shoot a resolution chart; from zoomed all the way in (and focused) to zoomed all the way out. I do this each time I stack on a layer of tape to the four points, and then once I get to about 6 or 7 layers of tape, I import the footage for review. I trim each video clip to begin at the zoomed out portion and blow them up to 300%. Then I can simply flip through them and find out exactly how many pieces of tape give me perfect back focus.
@QuickHitRecord Was that an easy correction? My 35-70 is almost parfocal but not precise.
The Minolta MD 35-70mm f3.5 (macro version) is the best zoom that I have ever owned. Once I corrected the back focus on my adapter, it is parfocal.
I suggest you to check @nomad 's guide: http://www.personal-view.com/faqs/camera-usage/minolta-rokkor-lenses-faq
I've built my Rokkor filmmaking set (24, 35, 50, 85, 135 and 35-70) following his advice and I'm more than happy with all of them. They look beautiful on my GH2 and match quite well (with minor color adjustment) with my SLR 12 1.6. I'm also planning to use them on the BMPCC if I go that route, pairing them with Metabones Speed Booster.
In fact, I might have became a Rokkor fan myself.
I suppose you'd see the difference between the 135s only in photography.
The 28mm is excellent in both MC or MD, the optical formula is identical, only the flare resistance might be a tad better in the later version.
I really love the Minoltas, but Zeiss Contax lenses are worth a consideration too. The 135mm and the 28mm in 2.8 are still out there for reasonable prices.
Canon FD has quite a few aficionados here as well, but personally I found them a bit too lo-con.
Hi to all,
I am looking to invest in two vintage minolta lenses and I need somme advice. I do only video with my GH3. After reading about Minolta lenses I am still confused as for the impact of what's been said on video usage. I am planning to get the 135mm 2.8 MD 5/5. The 4/4 version seems to have better reputation on sharpness, while the 5/5 version is less sharp and more contrasty. How does that translate on the image in filmmaking? Will I see the difference between the two on the screen? how? (someone here said there is no real difference between the two in daily life usage: http://www.flickr.com/groups/xd-11/discuss/72157603856330887/)
The same question would be asked about the 28mm 2.8 (early vs second generation) for I'm planning to get one as well.
I am looking for vintage lenses to get a softer more organic look than the clinically sharp rendering of the modern electronic lenses. I hate the video image look coming out from my pane 14-140 while I love the feel of the one coming out of my SLR magic 12mm 1.6T.
Maybe I should checkout other vintage brands?
Any thoughts?
Many thanks
The Rokkor 28mm is a beautiful lens, but it's harder to find than the Kiron (and often much more expensive). It would match the other Rokkors better, but I've still got a soft spot for the Kiron 28 f2.
DrDave is right in bringing up the bokeh of the Kiron, it can be a matter of taste, but for video, personally I really love it and I don't find it distracting at all. In fact I like the uniqueness and can use the lens to help craft a certain look or feeling. Don't forget the amazingly beautiful way the lens flares under certain circumstances.
Also, I want to mention I recently started collecting some FD glass, which I'm really digging. It seems like the old FD glass is pretty low contrast, which helps me squeeze that little extra bit of latitude out of the relatively limited dynamic range of the GH2 in video mode. I've been having lots of fun with the FD 20mm f2.8, which is a decent wide-normal FOV and is pretty damn sharp at 2.8. I can't wait to slap a speedbooster on that baby.
Ever compared the Rokkor 28mm 2.0 ?
The Kiron F2 has some nice color but I find the bokeh really distracting for video.
I'm a little late to the party here, but I'll offer my opinion: I shoot video, often on a GH2. Right my now favorite MF lenses are the Kiron 28mm F2 (a really great 'normal' lens for MFT). I also LOVE my Rokkors: 40mm f2, 50mm f1.7 (even though they are a bit plastic'y), the 58mm f1.4. I've been looking at the Rokkor 85mm f1.7 and the 21mm f2.8, as well as the Kiron 105mm f2.8 Macro (a true legend).
I do also own a some other MF lenses, like Super Takumars (35mm f3.5/50mm f1.4) and Vivitars (24mm f2 and 28mm f2.8) along with some other random old M42 lenses inherited from my grandpa's dusty old camera bag, but in my own personal opinion, the Kiron plays really nice with the Rokkors, which of course match REALLY closely, and I find these lenses produce the most pleasing image to MY eye on my GH2.
The Vivitar 24mm f2 is a pretty decent lens too (although a bit softer with more glow wide open than my Kiron 28mm f2), but the main reason I don't use it is because the front element rotates when changing focus. When I'm shooting with my rail system and mattebox etc, it's not a big deal, I put a linear 4x4 polarizer in the mattebox instead of a circulular polarizer on the lens (ND can go either on lens or as a 4x4 in the second mattebox slot if needed), but when I'm trying to keep the camera build smaller in size, I don't find this lens gets as much use.
The Kiron 28mm f2 has been practically glued to my GH2 and I feel I should mention that it has the most amazing and beautiful lens flare I've ever seen on a photo lens (without an anamorphic adapter). It produces a very lovely cinematic look and is a bit of a sleeping giant - I picked mine up for $40 (!!!!) with a stuck aperture, and fixed it in about a hour of repair.
@drbuckyballs same one like for any other MFT camera: Minolta SR mount (MD/MC lenses) to micro four thirds
This one is cheap and good:
http://www.ebay.de/itm/221021088813
what adapter is required to mount rokkors to the gh3?
For some added lens resolution test info. on old Minolta lenses, I found this to be quite interesting:
http://www.paulfvs.dds.nl/lenstest.html
I have Minolta 24mm f2.8 MD W Rokkor-X and 28mm f2.8 MD lenses. I'd like to try them on a FF camera!
Detailed Minolta lens chronology:
http://thesybersite.com/minolta/historical/Minolta_Lens_Chronology.htm
General Minolta lens info:
http://minolta.rokkor.de/minoltalenses.htm
http://www.rokkorfiles.com/Lens%20History.html
Minolta 28-mm and 50-55 f/1.7 lens info:
http://home.kpn.nl/dielpeet/minolta/Mainpage.htm
I have the MD 28-mm f/2.8 7/7 and 35-mm f/2.8 Celtic MD. They're sharp and have good contrast even wide open, and they have exceptionally good flare resistance - nearly as good as a modern lens such as the Lumix 20-mm.
My 50-mm f/1.4 MC Rokkor-PG performs better than a similar age Nikon AI, but I wouldn't call it a stellar performer for a fast 50-mm lens. Wider than f/2.0 the image gets hazy. I have no complaints at f/2.0
My god, did they get that expensive in one year? I bought the 58mm 1:1.4 last year with a stuck aperture für 50 U$, had it cleaned and repaired professionally for 30,- Euros…
Most vintage lenses do not resolve as high as modern glass. Consequently, they handle in-camera sharpening better than contemporary lenses. For example, I've found that all my MD and FD lenses work best in the GH2 with sharpening set to +2. There is no artificial edge - the picture looks just right.
58mm Rokkor f/1.4 (I will grab the more complete name later)
A nice character lens with beautiful bokeh. Used it for both stills and video work. Definitely not the one to call on when you need super-sharp, but flattering in everything from detail to color.
The most complete listing of Minolta lenses I have found
http://minolta.eazypix.de/lenses/body_li.html
Analysis of this list and perusal of ebay photos will help you spot the bargains and spot the poorly described.
Some excellent Reviews
http://www.rokkorfiles.com/Lens%20Reviews.html
An ebay store 'gokevincameras' that has a lot of nice Minolta glass.
http://stores.ebay.com/goKevincameras/Minolta-MC-MD-/_i.html?_fsub=14
I have bought one lens from them and was happy with the service, it isn't exactly bargain price .. but it's available.
