Rhino Slider
    Description:
    The Rhino Slider equips you to film 48" of cinematic glory. The system is based on 6 rollers filled with 12 sealed ball bearings mounted to a hard-anodized aluminum carriage. There is so little friction you can use gravity to move your shots. Locking all-terrain legs come standard with non-marking custom molded rubber feet that will grip to anything.
    Features*:
    • 2 mounting screws are included: Standard 3/8-16 for your ball or fluid head and a 1/4-20 for mounting your iPhone or GoPro
    • Dual locking friction brakes (not shown) keep the carriage in place when you're moving from shot to shot or traveling
    • The entire system dissassembles with only 4 tool-less fasteners
    • 3/8-16 & 1/4-20 threads on both ends of the slider for mounting to tripods
    • 3/8-16 thread on both ends for vertical mounting
    • Replaceable feet let you use suction cups to mount to a car or window
    Specs:
    • 48" Stainless Steel Tubular rails
    • 6061-T6 Hard Anodized (Type III) Aluminum
    • Weight: ~5lbs
    • Stainless Steel hardware
    • $400
    *This is for the base model. There are also carbon fiber "Pro" versions available for a higher price.
  • 1 Reply sorted by
  • Some video reviews:
