Editing like scrubbing FCPX help please
  • Hello,
    I am working on a project in FCPX where I constantly need to reverse, speed up, and slow down my clips. I basically want to be able to change "time" in the way you can do this when you scrub back and forth through video. Or the way a dj uses a turn table.
    Is this possible, if so how?
    Thanks so so much
  • 1 Reply sorted by
  • You know about the Retime command, right? To change timing of the output, select the clip and use the Retime button or press Command-R. If you need to do several operations on the same clip or a portion of it, you can duplicate the clip or use the blade tool to cut it in pieces.
