12-35mm F2.8 Panasonic lens topic
  • 492 Replies sorted by
  • I also received a replacement lens (SN: XT2...) and this lens has no jitter.
  • Dear Mates I would like to share my happiness !! cause finally I got my last copy of 12/35mm replaced , and no jitter issues at all ! ( I did all test in manual and AF , OIS on and OFF , but still I didn't yet a test at different angles degrees ) I can't believe after 6 months , between 3 lenses replacements , tests , experiments and frustrations , now I can really enjoy the quality of this lens. The serial is XT2 . I would like to say thank to those who have contributed to make this known in all forums , and discussion about , and that helped us get in contact with the Panasonic World assistance. and Of course PV forum too. I want to say thank also to my Italian Panasonic Assistance ( Marraghini AREZZO Italy) for the professionalism and attention that they had to solve my problem . Still the fact that Panasonic has no yet explained the reason why !
  • Even if we agree that the image is perfectly acceptable/fine (which I do for my usage), one of my concerns is that this constant movement of the lens, even with OIS off, has to be a symptom of a problem that causes unnecessary consumption/waste of battery power when we use that lens. I am of course not saying that battery capacity is a problem as it is - we all know it is excellent - but maybe it could be even more so? :)
  • Did another small test regarding AF. Angle -45 degrees. Switched Off continuous AF. Prefocused once and set manual focusing mode. Made two clips OIS ON and OFF. Exactly same as with focusing ON. OIS does not matter. You say you don't see the jitter in my video but it is definitely there at 300% about one pixel. No jitter at 15 and 0 degrees.
    Personally, I don't see any problem here. If I had the jitter at smaller angles or if it was noticable at 100%, I would consider it as an issue.
    Today I did a thorough long exposure still shots test regarding possible blur. I confirm there is no jitter related issue at all. I did test series at angles -45, -15, 0, +15, +45 on tripod. In every serie I used manual focus: prefocused before the first shot and locked the focus in MF. In every shot the shutter was released by 10 sec. timer. One serie had 8 shots, all combinations of next:
    • Mechanical/Electronic shutter (MS/ES)
    • Short/Long exposure (short was 1/80 and long was 1 second)
    • OIS On/Off
    Long/short exposure shots are equal in sharpness at any angle or OIS state. I have noticed a slight tendency for blurring while using MS comparing to corresponding ES shot. Nothing to worry about at all. It is understandable and less than a pixel in 16MP shot.
    As a conclusion I would say I'm happy with my lens copy regarding mentioned jitter issue. The thing that disappointed me a bit is a noticable vignetting, especially at the wide end and open apperture.
    Btw, I did also some 15 seconds shots at ISO 200, horizontal (zero degrees) and very dim light so that colours are almost indistinguishable for naked eye. The result is stunning: bright natural colours as in day light and the shots are razor sharp.
  • @valpopando
    OK, I will check out them when I have time.
    At least, there is no issue in my using other Panny lenses. And the issue which I experienced seems to be the same as it in your videos. Furthermore, I also make Panasonic investigate it. :-)
  • In all my tests AF was always on, just for your reference. To me this is clearly something with the OIS, anyway I just hope Panasonic can fix it via a firmware update
  • @bkmcwd Wait a moment , if it happen only while AF is focusing maybe there is nothing to be worried . Is better if You check out our previuos posts and take a look at videos tests , trying to follow how to perform the test. because in our cases the shaking issue is always presents , not only during AF
  • Try with AF off? If i get time tonight, I'll try.
  • @valpopando
    "Unlucky 12-35mm team"
    Yes sure. ;)
    In my experience, it is thought to me that it is shaking only while AF is working. Although ON and OFF of OIS are not related and it happens, it does not occur, while it is in focus.
  • @bkmcwd welcome in the "Unlucky 12-35mm team" , But I guess is a OIS issues
  • Hi :-)
    I also noticed this problem today. Soon, I also ask Panasonic. Although I am not reading all the past comments, I think that AF is doing mischief.
  • @Nakame78 that's a good news Mate !! after these latest developments, Yesterday I've called Panasonic Italian assistance , and they allowed Me to make another change , and as you did, I asked for a XT3 serial. So finger crossed , and I will keep informed as soon as I will receive replaced.
    @Vitaliy_Kiselev thanks for adding a new review
  • To be precise I would like to mention that the lens I took to the dealer has been with them for weeks, even though they told me that they would send it right away to Panasonic Japan they never did so. So the story about "normal functioning" of the lens does not come from Panasonic, it comes from the dealer itself (Bic Camera, if you know it). Eventually they sent the lens to Panasonic Japan, together with the videos I took that show the issue, so hopefully they will get to the root cause of this problem
  • @mee yes I am in Tokyo, might be a good idea to go to Akihabara directly to Panasonic office. My lens is with Bic Camera.
    @ge0rge thanks for the video, I agree with valpopando that I do not see any jitter in there.
    I have just finished the testing with my new copy of the lens, here are the results I obtained with the new 12-35mm lens (serial XT3B).
    • 12-35mm lens at 35mm with OIS OFF -> jitter still visible, clearly visible if I take the video with the digital zoom 4X enabled, not much visible at 2X digital zoom enabled and not visible when digital zoom disabled. The linked video is taken at 4X digital zoom.
    • 12-35mm lens at 35mm with OIS ON -> jitter is gone! Tried with digital zoom 2X/4X and without, I never see any jitter. With my old lens I could see the jitter regardless of the OIS setting OFF or ON. The linked video is taken at 4X digital zoom.
    As a reference I tried again with my 35-100mm lens at 35mm as well, there is NO jitter visible in any test I have done (OIS ON/OFF). Videos not uploaded.
    Now although this is an improvement compared with my previous situation, I still don't get why with OIS OFF I see the jitter, especially because the 35-100mm lens performs well regardless of the OIS setting.
    Anyway my original lens is still with Panasonic, so I am still waiting to hear from them what the problem is
  • @valpopando, thanks. This is reassuring! Now I can start learning about this gh3 finally with a lens.
  • @test12 thank You ,
    Your lens is solid as rock , as ge0rge copy , at this point I dunno , Is not about serial , is not about seller or certain lots or geographical area , is just random ... I was unlucky
    @ge0rge yah sorry I miss that in your previous post
  • Valpopando, Serial number starts with XT3AD..... See my post above
  • @valpopando thanks for your reply. My lens serial # prefix is actually XT2 and it is from Japanese seller on eBay. So should I not worry, then? Are there any further tests I should run? Did you watch it on 200% or more? I noticed above this is common test? I did another test with text so you can see clearer. Note movement in first and last seconds is from my movement turning video on and off:
  • @test12 and @ge0rge I can't see any jitter on both videos ,or rather not the kind of jitter we are complain ! would you tell me what serial number your lenses got? just the start , XT2 or XT3 ?
    and @Nakame78 I'm waiting for your XT3 lens test outcome ; ) ) thanx a lot
  • Nakame78, Here is my clip:
    My first video uploaded to youtube. I uploaded 40MB MTS. Youtube transcoded the video to bitrate 4 mbps. So it looks more blurry. But if you download and zoom, the effect looks almost same as in original. Less noticable because of extra blur.
  • Hi, Just got my 12-35 and GH3. I did a short test and could not see any jitters. Is my lens solid or am I not testing it correctly? I know this might not be a real life issue if I cannot see it, but would apprecitae your feedback. Here is video with lens on GH3, tripod, OIS off, tilted down about 45 degrees:
  • Nakame78, if you still have problems, and are in the tokyo area, you should go to Panasonics office in Akihabara, it is a little tricky to find, but not too hard. I may be going there soon, and plan on mentioning the 12-35 issues.
    I am guessing you have been dealing with Yodobashi. I have never had a simple return even for little items, with them. I have had them tell me stuff that I know had 90day in store warranty was credit only, but soon after they gave me cash because I refused to play their game. It seems to be their policy to make up stories. I suspect often they aren't really talking to Panasonic, just pretending they did thinking it will get you out of their shop. For those in the US, imagine Walmart but instead of their easy no questions ask return system, they go to their manager three times each time coming back with a different excuse why they can't give you a refund or exchange, until finally they do the right thing simply because you are too stubborn to except their BS and understand their policy better than they do. Unfortunately many Japanese are too polite and trusting, and except the BS.
