Bought a used LX7 from Amazon for $277. It will be here tomorrow. It will replace my Canon S100 as my new butterfly cam. We take a lot of butterfly pics, the wife and I. Also bird pics. Anyway, I was going to wait for the Canon S110 replacement but the following features sold me on the LX7 as my walking-the-trails butterfly cam.
-fast lens at both ends. My S100 is a bad 5.9 at the tele end. -quick manual focus rocker switch on the back -Macro up to 1" from lens. That's huge for me. Sure, it won't replace my Oly 60mm macro/GH2 combo for tack sharp large pixel pics but it also goes in my pocket which is what I need while on the trails looking for butterflies. -1080 60p and that nice MP4 1080 30p feature -720p 120fps will come in handy for pretty butterfly wings slow motion. Can't wait to try that out. -physical Macro AF switch on side of lens...very nice I believe that will be. -my FL360 flash will work with it. I hope the the FP TTL feature works with the LX7 -the intervalometer is nice but sadly limited to just 1 pic per min for 60mins...sigh
I read all of the review out there and it seems I'll probably set the LX7 to 800 ISO limit as stuff above that didn't look that good. We'll see.
As for my Canon S100, it's got the CHDK hack and is outside right now taking motion detect pics of birds on one of our perches.
Can't wait to get the LX7. Thanks for all of the tips from pages 1-8 here.
Harold
Dusty, if you hit "display" you can make it appear again. I would hazard a guess that you've hit the button before you started your recording, and that particular "display setting" just makes the info dissapear after a few seconds.
Thanks for the comments on my little radio show. Shooting it myself without monitoring the cameras sucks. Generally as everyone knows, shooting towards a window is problematic. I think a filter would help and I use variable NDs all the time (I wonder if a CP would be a good choice). But guys, the cameras are all in the wrong place on my show. At least, I fixed the previous focus issues!
I'm considering picking up a used kit on KEH (they're now pretty cheap) which would let me go wide (and high) on the two GH1s and use the LX7 between us. The little Kodak zi8 should be traded in on a GoPro, because the gal on the boards is much easier on the eyes than the two of us.
By the way, I'm now fully switched to FCPX. I don't even use Plural Eyes anymore (although I still have it if I need it).
Here's a cheaper alternative to DMW-FA1 filter adapter.
http://www.ebay.com/itm/171002674441?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Hi fellow LX7 owners,
I have an issue on my camera and can't find a setting anywhere in the manual that I can set to fix the problem. After recording about 1 minute, the camera shuts down all the information on the display; the information such as shutter speed, aperture, battery level, etc... diappear from the screen.
Do other cameras have the same problem? I can produce the problem consistently. Hit the record buttom and simply let it run for about 1 minute without touching anything and all the information is gone from the screen.
Thanks.
@DailyFilmFix I stopped fighting the stupid 30 minute limit on my LX7 by buying an FZ200, and I have never looked back. No 30 minute limit, excellent 1080p wrapped in AVCHD. Most of the other features and menu setup are the same as with the LX7. Currently on sale for $429, I wouldn't hesitate...
Sure it is not having problems because of the bright outside light in the window? To me it looks like it tries to compensate for that.
"The wide with the window in the back ground is the LX7 and it looks awful in 720 compared to the other cams" In this video
I would change LX7 to the lady instead the wide shot with two guys and window background
My experience has been that the 720p does not mix well with my hacked GH1. The image quality is the problem, I think. Honestly, I've not tried it in a professional setting on a regular paying job. My little TV show is self-shot (with 4 cameras), and it is a very small and frustrating space--a radio station studio.
But I do set everything (except focus with the LX7) manually. My custom film profile is -2 across the board on all cameras and white balance dialed in eyeballed. I'm not sure what film profile on the LX7 compares to "smooth" on the GH1. I used spot monitoring and under exposed a couple clicks (I try to do this all the time). And this week, I just guessed wrong. Look for the example when I post the show.
I have another documentary project starting soon, and it would be awesome to have a hack for the LX7 by that time. And I need to donate, I know.
The fast lens and ability to shoot completely manually makes the LX7 great. If the bitrate was increased and the clip length limit were lifted this camera would be a terrific true "C" cam for me.
You are correct, vbr can result in lower bitrates than the specfied maximum (I was not sure you were talking about the bitrate minimum or the spec (max)), and an efficient processor does vary the bitrate a lot. And as you say, still scenes do not require a lot of bits, unless there is a great deal of detail.
Most manuals specifically recommend turning off the OIS if a tripod is used.
Thanks for all your replies - and corrections Markr and Vitaliy.
Markr - the codec data output is variable, so if you shoot a shot where very little is happening - then look at the file Length vs size = rate you can end up with ... see attached report from windows. (Note that other files it confirms the right bit rate almost all the time, just some of these more still long video shots its well under the bitrate. Where i am shooting 720p/60 and geting 7-8Mbit. I saw this happen a few times when the camera is on a tripod ... now with the GH3 it will tend to use the bitrate.
Optical image making pan stutter - great to know. I am in your debt. I started using Nikon manual lenses which obviously don't have OIS and i am getting a good fluid-head so i can see how when OIS is your friend and when it is not.
I see this a lot with live video streaming codecs - and yeah, it can be great to have a lower bit rate and smaller file. You can rejoice ... if the codec did its job but when i look at the image quality, i am not sure its tuned right - could be getting more detail. So ... just imagining how something like the GH2 hack could benefit video quality in future if it happens.
@itsjaba: "Its clear that it jumps and skips in panning situations and so an all Intra hack of any frame rate would of course be a magical thing to have, or just higher bit rate as others say."
No. Jumping and skipping is not a codec issue but may be due to optical stabilization, which has a difficult time distinguishing betweeen unwanted camera movement and deliberate movement. The result is that it resists at first to the camera moving. Macro blcoking is what occurs from codec deficiencies. If what you observe with camera panning were a codec problem you would see moving subjects (holding still camera) "jumping and skipping". You do not (unless the subjects are actually jumping and skipping, if you know what I mean).
"I also wish 720p would have higher bit rate, its right down in the 7mbit zone ."
No. The LX7 72060p is 17Mbps, not 7. That is comparable to the 28Mbps for 108060p.
The need for higher bitrates for AVCHD is not as obvious as most people assume.
To Vitaliy - do you need to wait for a firmware update for LX7
Yep.
Venus is marketing term. But LX7 seems to be from same generation as G5.
I have been mixing Lx7 with my GH3 video footage ... on occasion they mix well but, most of the time they don't work so well. I would like to see some control over frame rate like a 24p mode. I understand it could take a really long, long time for conditions or access to firmware to reverse engineer. So for the mean time it would be good to get suggestions for best settings. I pull my LX7 for close shots (if i don't have time to change lens on GH3) or for low light because its good. I am not the only one who just bought LX7 because its like getting a fast+macro lens with a free camera.
Its clear that it jumps and skips in panning situations and so an all Intra hack of any frame rate would of course be a magical thing to have, or just higher bit rate as others say. There are things you can do though, shooting depth of feild where you have a lot of blur around subject - your codec will handle that excellently and then the LX7 performs great. I also wish 720p would have higher bit rate, its right down in the 7mbit zone - would be fine to use 720p but its not as nice as the top end 1080 even for faster motion shots in my limited experience.
I am honestly just still learning a lot so sharing video - good video and saying how it was acheived on LX7 is great. The best hack is understanding how to get the most of what you already have without waiting for a magic bullet.
To Vitaliy - do you need to wait for a firmware update for LX7 or are you reading whats on the camera to get kicked off? Assuming you have time at all for this. Its Venus engine, does it have same number of CPUs as GH3 does? Is Venus engine just a marketing term and the CPUs are completely different - given that i am too chicken to open my cameras and look at the actual boards inside.
I'm very happy with the camera for video. The problem I'm having is that I haven't figured out the best use for it on my local TV show. For example, this week I decided to use it wide but unfortunately pointed at the window in the radio studio. At 720p, the camera did not handle it well. It would have been better on me and one of my GH1s in the wide position. Next month, I'll get it set up better. Look for the March show link this week.
I fully intended on using this as a wide camera, or mid-close in multicam situations which will be required. I'm also in the midst of planning a short film in which I plan on using the LX7 as my primary cam. From the tests I've seen, the little F1.4 lens is really impressive.
My guess is, I will have less problems cutting my LX7 footage in with my GHx footage than I did with my HV30 "b" and "c" cams.
Most of the weddings I shoot don't last longer than half an hour anyway... and if I have to run back and hit record on the camera, then so be it. It won't be as bad as shooting with a Canon DSLR where (without ML) I have to run around and hit record on my cams every 12 minutes.
I've made the purchase on this camera already, I should have it very very soon.
when will the hack - Vitaliy?
Daniel, I use the LX7 with my two GH1s. When everything is set for 1080p the three cameras look good together. Plan on using the LX7 for a shot where you're not worried about shallow DOF. The lens is good for some lower light conditions, but it won't compare to what you can get out of your GH.
My problem is that I have to shoot my little radio/TV show on 720 because of the clip length. The lower bitrate of the 720 on the LX7 is noticeable next to what I get out of the GH1s. Seems like the clip length is a priority over 24p, but having both and higher data rate would be ideal.
In Windoze I use process troublesome clips using AVIsynth and Virtualdub. K-Lite codecs provide all you need. But these are tools for people who are familiar with using scripted programming languages. They are free, and they can do just about anything. Plenty of plug-ins for both -- for example -- Gunner Thalin's 'deshake' filter for Virtualdub is superb, and very configurable.
IMO, to handle AVCHD Lite it is best to create the DGindex and AVIsynth command files with MeGUI (another free tool).
But I am lazy, so I use Cineform for my main codec, Sony Vegas for the final mixdown... Both are commercial packages costing more than the LX7. Both save me time and keep the overall quality high...
Finally, I have stacks of 2TB RAID 1 arrays to store footage for posterity. The drives are cheap. I have fire-proof boxes full of old footage (it will come in useful one day LOL).
The originals from the camera is fantastic no matter how fast I pan around. Off course that is 50fps but it should be possible to get better results on 30fps than what I get. Take the start of this video. I need to learn more about codes and setup. What free codecs do you guy use out there? (or even what is worth paying for). The only thing I do mostly is to enhance the contrast and sharpen a touch. But I have had the problems before I started doing that. http://vimeo.com/jojoen/vaset17130006
Jojoen... it looks as if you've done something to your video to induce motion blur (I've not seen that on other example videos).
This camera is going to be my next serious purchase. I've just sold my old HV30 to someone as a tape deck/capture station (such a waste, as the camera is amazing... I just don't care for miniDV anymore)... and I've got a little cash to spare. Also, I like to shoot with at least three cameras, and seeing as I already own a GH1 and GH2, I figure adding another lumix to the mix can't hurt. I may even be shooting a short film with just this camera (and seperate audio of course) in the future. Unlocking a 24p mode on the LX7 would be the first welcome thing for me... as I shoot 24p on all my cameras.
Also, I understand the LX7 shoots 120fps in 720p. It'd be great if we could feed a little extra bitrate into that mode, to make sure quality is up to standards!
@jojoen Usually it is noise which takes bandwidth in my low-light video. I use the Dynamic Noise Reduction filter in VirtualDub or Sony Vegas to knock my noise down. I can't see any motion from the pan which is likely to be really bandwidth-hogging. The video you have on Vimeo has a very low level of noise, so the question is whether it was pulled out by the codecs or by pre-processing?
Some of my latest videos: Low light conditions (less than 100watt lamps dimmed total and two fires)
Very high light conditions: http://vimeo.com/jojoen/vaset17130006
The only thing I really struggle with is finding a codec that makes a video smooth while panning without having extreme bitrate (that dissapears with uploading anyhow). Anyone with a tip or two? (I have Premiere Pro CS4 and Vegas Pro 12.0)
For me HDMI / video output while filming is what I want mostly. Higher framerate full HD and possibly a better high speed frame rate with manual settings will also be fantastic. And off course the 30min maximum raised would be nice. My camera is the PAL version so settings is 25/50/100 frames. Having 30/60/120 NTSC would help in some ways so I dont care if I need to change to NTSC software ;)
So, I guess my question is this... If the LX7 cops a hack, what can we expect? Possible 24p/25p framerates? Upped bitrate? I'm just finding it hard to see where the hack could improve this camera... unless I'm missing something.
I have LX7 at hand. As for hack I'l try to add some infor about it in March update.
