GH2 multiple SD cards, swap hacks
  • I'm trying to figure out if I can copy hacks to SD cards and switch between versions. I'm wondering for instance if I can load a hacked patch on SD and then bring a stock firmware card with me on a shoot, switch back and forth. I'm assuming you can't do this because you would have to increment the version in Ptool each time?
  • 2 Replies sorted by
  • yes you can. you have to make sure version increment is checked so cam doesnt check for increments. your only issue is having a full battery when updating each time
  • I don't increment the version hacks. All are named GH2__V11.bin. To keep track, I have a folder and put each patched version in different folders. ie Cluster Nebula 6, Spizz. Then copy them to separate SD cards. If you carry a laptop with you, you may not need separate SD cards.
