@allenswrench are these higher rates capable of bricking a camera? or only of crashing it? (If it won't brick, I'll give them a try too. I don't care about crashes as long as it doesn't do permanent damage.)
Off to Macba in Barcelona to try it out....might not be the best way to test but am restricted to studio lights until saturday.... But... no me jodes - are we the only ones running the high patches?
Did you say earlier that the SD card actually gets hot? Really? If so, that's a good indication that you are pressing things close to the limit!:)
I think we are getting two conversations mixed up here. Your settings seem fine. The additional buffer stuff @Mihuel is trying is just another experiment, and that's what I've been responding about.
cbrandidn, did it not work? it is the straight out of the box VITALIY patch, note the changes 880000 bitrate in the 24h section OPTIONAL 3GOP for all other it really is as simple as that!
ANYHOW anybody can do it following the settings from the text file Although these are lovely settings made possible by our friend V remember to ONLY use fastest cards as you would have film a few years ago! Happy shooting!
OK, rendered the first test, they are nice. Before anyone starts screaming RED etc, they are nice GH2 files, I even tested hard for jello which will always be there.... For under a 1Grand this is really nice, thank you Vitaly, if I ever do any projects I will donate more! Lets not forget this is an acquisition from a medium size sensor at 8 bit - do not expect miracles. On the other hand, most content is viewed at 8 bit or less..... like most music is consumed on kitchen radios...
@cbrandin I have not changed any buffer values I have loaded up the new firmware with the default values. First time I changed the 24H bitrate to 65 and all was good. The second time, I changed that same bitrate to 88 and the GOP to 3. Still works- no artifacts, the only negative change I have is that the camera will not span to new file after 4GB like it did before.
@ danyyel the bitrate WAS falling with the default settings where I just jacked up the bitrate to 65. Now, the bitrate seems to hold steady between 80 and 90 all the time.... This was with the default new hack settings. Please, someone smarter than me tell me that just changing it to GOP 3 (which I personally detest) tell me that it is what is keeping the bitrate steady and huge.
I just noticed that you went too high with the buffer values, they look like 4x, not 3x - and your bitrate (for 24H) is only 3x. Those buffer values would be more appropriate for a bitrate of 88000000. Maybe it might be worth a try with the buffers set at 3x.
I think Vitaliy's suggestion is good. It looks like the codec is not responding to a larger limit for I frames very well. It kind of makes sense, because with more I frames, you wouldn't want the codec to try to max out individual I frame size anyway. It looks like you aren't getting the bigger frames with short GOP, so those patches serve no useful purpose.
