I'm going on a trip on a couple of weeks. What would you say is the best setting for me to use: stock, Galaxian V1, Galaxian V2? I'm trying to achieve the best resolution that I can (without buying a GH2 :) Thank you!!
Is it possible that ptool will be able to increase the fps of the GX1 to 60fps or is a mechanical limit of the shutter holding it at 25fps?
No
Does that mean it would not be possible to lower it to 24fps as well?
as I know, it's some kind of sensor mode limitation. That's reason why it's not possible or it's extremely difficult.
hello. I have a Panasonic GX-1 and 95 MB SD card. Which of setting up for me will be better ? I tried Cluster X Series - 'Spizz' - 3 GOP - Trial 3 - setc. but the video is twitches and MP4 format does not work. and I need a setting for time laps. Please help
I understand it correctly. I can use the patch settings from G3 ? This is the same camera in the Inside?
@slovach Have you tried Galaxian? See link below;-
Bottom of that comment - last setting attachment is Galaxian under Cluster heading
Yes, I used it for 3 days, it is the only fix works stability on May GX-1.
Galaxian I have only one problem Video 720p AVCHD I want it to look in the camera, he says of a read error from the memory card
can someone tell me how to use the timelaps pach in GX-1
@slovach Im looking into improving AVCHD modes of Galaxian on the GX1 shortly. However, the .Mov modes ptools are problematic at the moment.
Thank you for your work
and for quick answers
What is the time lapse patch for the GX1?
This is when the video is recorded at a rate of 2 frames per second
http://www.personal-view.com/talks/discussion/2920/gh2-timelapse-videomode-2fps/p1
http://www.personal-view.com/talks/discussion/595/mjpeg-fps-setting-for-timelapse-on-gh2/p1
@slovach New setting for GX1 coming over this weekend. :-)
@slovach Can you try out the Cluster X settings on your GX1 and let me know what works and what doesnt.
you're talking about this Driftwood - Cluster X - DREWnet 12-15 Classic GOP (TRIAL 4) - MEGA Quantisation
I tried 1GOP intro Moon trial 3
All videos are shaking
Mpg4 not to recorded because of the speed limit of the card
this "Claster Drewnet 12/15 GOP trial 5" all records, not shaking. But the camera play only 1080 AVCHD
I think DREWnet 12/15 GOP is probs the one that'll work best for GX1. The mov modes are'nt working properly yet and need to be addressed by VK. Ill be uploading Trial 6 shortly as Im testing a very low quantisation of 6 which now matches (and in somewhat many cases beats) the GH3 for quality.
I tray Cluster Nebula 6 GOP trial 5b
On the computer is playing well, but the camera does not play, does not record MPG4
6GOP 43572 kbit/s this is a good result. I have a question.
What is the essential difference between DREWnet 12/15 GOP vs Cluster Nebula 6 GOP trial 5b ?
I think Nebula 6 GOP more smoothly
hello Have any news for GX-1 ?
I watched the video in PremierPro zoom to 100% And I found that the hack (Cluster Nebula 6 GOP trial 5b. 720 mts) provides more detail than (DREWnet 12/15 GOP) ( Cluster Nebula 6 GOP trial 5b. 1080 mts)
Please use other topic for settings discussion.
