Special deals: Jibs, cranes, dollies, sliders
  • Send me personal message (on the left column at http://www.personal-view.com/talks/profile/1/Vitaliy_Kiselev ) if you want to purchase any item here.
    Carbon Portable Jib, Crane
    Specifications:
    • Arm length - 200cm
    • Packaged length - 80cm
    • Minimum radius - 75cm
    • Maximum radius - 120cm
    • Max operational height - 290cm
    • Min operational height - 20cm
    • Counterweight ratio - 1:2
    • Max load - 4kg
    • Net weight of jib - 1.8kg
    • Tripod and head must be designed for 5-8kg load
    See Water Weight option below!
    Price: $295
    Shipping: Includes fast free shipping for US/Canada/UK/Australia&NZ/Western Europe. Ask for any other regions.
    Limits: Very small amount, last while in stock.
    Carbon Pro Portable Jib, Crane
    Specifications:
    • Arm length - 235cm
    • Packaged length - 85cm
    • Minimum radius - 55cm
    • Maximum radius - 140cm
    • Max operational height - 310cm
    • Max load - 3.5kg
    • Net weight of jib - 1.55kg
    Price: $409
    Water Weight for portable cranes
    Specifications:
    • 25mm hole diameter
    • Very portable and light contrary to metal weights
    Available only as option to cranes above.
    Price: $33
  • 1 Reply sorted by
