So for the download files you say it would be best to convert in a 30p format?
It makes a difference if you editor makes good frame interpolation. If it just doubles frames, it'll be almost the same as 25p.
All this DVD stuff is really horrible. @AKED, start just writing 720p H.264 to 2GB flash drives and send them. WIll be cheaper and with much better quality.
But I have a question too. I produce martial arts instructional DVDs. I filmed up to now with a GH1 and a GH2 in 720/50p, so PAL, soon with the GH3 in 1080/50p MOV 50 Mbit or the AVCHD 28M bit version. I have to see.
So I edit on the PAL 720 timeline and render for PAL a PAL SD mp2 file for DVD production and for american DVDs I render a NTSC SD mp2 file. So far, no problem. The NTSC version does not look as nice., because of the different resolution and the other framerate.
Now, from the 720 timeline, I also render a file, that is for download purposes. If I understand it right, the HD resolution (720 and 1080) is the same in NTSC and PAL (contraty to SD), only the framerate differts. Correct?
@Vitaliy_Kiselev I think yes. Probably a feature that the big companies think is neccessary in Europe, that they can play back NTSC DVDs, but do not think neccessary, that NTSC players can play back PAL DVDs.
@Ralph_B Two different things: A, Many TV can accept the 60 Hz and playback the signal that the DVD player sends. Also, when you connect a native NTSC DVD player to this TV set.
B, Stand alone DVDs player play back the NTSC DVD which can be watched also on non NTSC compatible TVs. The colors might be wrong, but you can see the content. This is not possible in standard US stand alone DVD players.
But the american DVD Player CAN NOT playback PAL DVDs. You have to buy a multiystem DVD player.
I got it. You mean playback of region free disks on original (with non removable protection) players. I think this is that you mean. This can be only special artificial protection.
As for DVDs, I have only old TV serier remaining on DVDs. DVD players are not really popular here.
Are you saying that PAL TVs will automatically sync to 60Hz if you feed them a 60 Hz signal?
It's true that DVD players in a computer can play both NTSC and PAL discs, but stand-alone NTSC DVD/Blu-ray players cannot play PAL discs. And NTSC TVs will not sync to 50 Hz.
But my question is can PAL standalone players and TVs playback NTSC discs?
"Who told you this? If you remove regional protection all play fine"
Sorry Vitaliy, that is not true.
In Europe, yes, all PAL DVD player can playback NTSC DVDs, when there is no regional code on the DVD. But the american DVD Player CAN NOT playback PAL DVDs. You have to buy a multiystem DVD player. Cheap, at Amazon.com for below 40 US$, but still: standard US Player do not playback PAL DVDs.
I sell DVDs to the US and that is the problem of the customers there with PAL DVDs. NTSC here in Germany, no problem.
NTSC devices cannot playback PAL discs.
Who told you this? If you remove regional protection all play fine.
What about DVD and Blu-ray discs? Can PAL machines and TVs playback NTSC 60i/p discs? The reverse is not true. NTSC devices cannot playback PAL discs.
Just to be clear, on an ipad, 25fps doesn't look better than 30fps, just better than a desktop LCD monitor or Laptop.
That's interesting @Rambo, I wonder if the ipad actively changes the scanrate for different content. I'm in a PAL country too, and all computer screens default to 60hz
I'm in PAL country (OZ) and all my outdoor shoots are 60fps then down converted to 30 for web upload. Why I changeover is when 50 fps is down converted to 25 and played back on 60hz screens it is very noticeably jerky, even tearing if motion is fast. Add this to the slight strobing from a 1/100 shutter and it can be uncomfortable to watch.
One strange observation though, 25p on an iPad looks much better, smoother, maybe it's the small screen, much better than on LCD monitor and laptop.
Will the internet force the TV industry to start producing more multi-system TVs?
I do not know that you understand under "multi-system".
All modern TVs can perfectly show and play all normal framerates (up to 60fps).
They do not have any restrictions.
My comment was about video mode on TV used during running internal youtube app or browser.
Most probably it is 60fps in all countries.
If the display frame rate is at least about 2.5x the content frame rate, it's not necessary to have a precise ratio like 2:1 or 3:2 between them for it to look alright. The player repeats frames as necessary to make up the difference, and our eyes are not too sensitive to the irregularity of the lengths of the repeated spans of frames. 30 fps on a 50-fps display is less than ideal, but 30 fps on a 100-fps display is just fine.
As Vitaliy said, if the web is your target format, I would not worry about people playing online videos on their TVs, as it's a small fraction of viewers. The vast majority play them on their PCs, which typically have 60-fps displays. For those viewers, 30 fps holds an advantage over 25 fps or 24 fps, both because of the higher rate, and because of the precise 2:1 ratio between the display rate and the content rate. The motion will be smoother and more uniform.
There is virtually no 60-fps web video delivery right now. Shooting in 60 fps gives you options for other delivery formats and for the future, but you'll use a 30-fps downconversion for today's web delivery. You can upload a 60-fps video to YouTube, which they automatically convert to 30 fps. Perhaps someday in the future they'll re-encode those videos and deliver them at 60 fps for suitably equipped viewers.
If you are targeting theaters, professional broadcasts, and Blu-ray, unfortunately 24 fps remains the universal standard, since there are clean ways of converting it to every standard around the world. That's slowly changing, with some theaters now able to show higher frame rates like 48 fps and 60 fps.
Right now it is very very small part.
And this requires detailed research. As nothing prevents PAL TVs to have default 60Hz.
Usually 60Hz is framerate of most modern monitors connected to computer. Of course, you could have some old CRTs with weird 85Hz, or some tweakers. But main mass usually have such rate.
It depends. But people are quite accustomed to look at 24p on 60p monitors despite all flaws.
If you are making things specially for online distribution, 30p and 60p just are better options.
Thanks! What about 23,976 frps? Is that better or worse than 25 frps for web?
For computers - 30fps or 60fps. Period.
