@HollyBoni
This patch is rock stable, I can ensure you- but use Sandisk Extreme 95MB/s. Period. My advice: 32GB and 24p instead of 25p, if it suits your work.
You will get high bitrates with sharp lens when the scene is very detailed and well-lit. LPowell took lot of care to make this patch and it is good that the bitrate is variable. The IQ is still excellent even then.
If you are high-bitrates-guy, try 3GOP patch by rigs, I've recently exported that settings and uploaded zip on that topic, as our mate rigs didn't do it (with early Ptool versions it was not possible yet).
i'm a little bit disappointed. today i finally tested the camera with some high detailed scenes. the highest bitrate i got was 38mbps with this hack, i shot everything in FHD AVCHD 25p. at this scene the camera always froze if i recorded a longer clip then 10 seconds. i have a samsung C10 card.
http://i47.tinypic.com/25f6el3.png (i didn't focus where i wanted but i couldn't see s*%t because of the snow it was soo bright)
that counts as a high detailed scene, right? media inspector says the video steam bitrate is 17.4mpbs, and the scene is very low detailed. is that normal or i screwed something up? i shot other scenes there, but they i didn't like the quality.
@CRFilms Fortunately, there's not often a need to film a test chart on an LCD screen! I have shot a few tests on my 47" :LCD, and the flicker seemed to be minimized by shooting at 1/80 sec shutter. With typical program material, none of the GH1 patches I tried had any reliability problems.
@zcream My high-bitrate GH1 patches were very sensitive to short-GOP settings, which I found pretty much impossible to stabilize. The only exception was the Fast Action 3-Frame GOP Patch, which worked only in 720p25/30 mode. With any GOP size below 12, the camera would shut off within a few seconds when exposed to darkness. In general, the GH1 has a much harder time with short-GOP settings than the GH2.
@zcream ...don't know/remember about changing this hack for GOP6 and low light, just for changing things to mess around with low GOP settings. The biggest problem with low light, is the GH1 is just weak in that area, unless you got a decent sensor from the factory, but if you got the standard FPN sensor, you're screwed. But, shoot faster than F2.8 or light it properly and you can get away with a lot more than you think up to ISO 800. OR shoot black and white and you can push to max 3200 iso and get usable images if you use the B&W Smooth film setting.
Here's my main problem with this patch and most patches on the GH1. I downloaded Pappas 2k chart, only chart I could find. I put it on my 42" LCD, pointed the GH1 till it filled the screen and EVERY patch I tried failed. Max Lat, stability, native 24p. Rigs GOP1, GOP4...everything failed EXCEPT....stock firmware, or stock except max iso hack. Not knocking the patches...it's the hardware....the GH1 just can't do that type of super detail. I tried the GH2 with one of the 160mb GOP1 hacks and a standard Transcend class 10...worked fine.
I tried Rigs GOP1, changed to GOP4 and that's as stable a low GOP as I could do. Ultimatly I don't know if GOP6 Max Lat would really be better than stock GOP. We need a proper, SIMPLE, test to see if GH1 low GOP is really better for movement, because in overall detail, my closeups of GOP1/4, Max Lat look pretty much the same to me, but I'm not doing locked off controlled settings.
I am going to dust off my GH1 to work with Aki's ideas for low light shooting. @lpowell What do you think of CRFilms idea of using GOP6 on your settings for low light.
It work amazing on gf1 and Transcend class 10!! 108 Mb/s en avchd!
Don't forget check "manual movie modes"
Thanks!
