Low Light Tricks
  • hopefully you'll find it useful.
  • 6 Replies sorted by
  • @all
    Lowlight: Under exposure is always a good way . . .
  • @Ralph_B
    Do you have any footage you can share, so we can see the results of your various work-arounds?
  • @brianluce
    The motion looks a little different at 1/25, but not radically so. Most of the time, you'll hardly notice it.
    The bigger issue is simply using the right tool for the right job. If you need to get more light into your camera, there are a number of different ways to do it. That's what my post is about. Experiment with them. Become familiar with them. Under different circumstances they will all come in handy.
  • @Ralph_B
    Great tip about ISO settings, I did not know that...
    @brianluce
    What don't you like about iso 800?
    I use ISO 1600 a lot and sometime 3200
    If the exposure is set ok it's no problem, if you underexpose you get problems.
  • Two suggestions on the list,
    1) You suggest 1/25th shutter at 24p -- defying the hallowed 1/50th rule. Is the motion signature going to change? Or is it not perceptible? The comment suggests as long as tripod is used, no advantage to 1/50th guideline.
    2) Shooting up to ISO 12000? Wow! I don't even like what 800 looks like!
