Nice
@azza_act 20mm Pancake, 25mm Nokton, 50mm Canon FD SS 50 All Intra 24p i think ISO 400-1250
@Lambo nice, what ISO and lens?
@mrbill standing up (on Vimeo) is an anamorphic test :-) anamorph does not look great, you're right. I load up the original tonight.
@Lambo - great dancers - wrong aspect ratio? Everyone looks a bit squeezed..
Manu4Vendetta, please tell us about AF-speed for Olympus 12mm. Is it quick enough compared to the Panasonic lenses?
Use http://www.personal-view.com/talks/discussion/5304/gh3-user-reviews-and-opinions#Item_200
It is more proper topic for owners.
@Trankilstef There are two different highlight options in the menu. You have "Highlight" in the "custom" menu to turn on highlights when you're viewing pictures taken, and "Rec Highlight" in the video menu to turn on highlights in the video mode. Maybe you've only turned off the image option in the custom menu?
Hi GH3 users ! Does anybody activated the highlight function to prevent any blown whites? Cause I turned it on to test it, and when I decided to turn it off it doesn't work ! So wether I turn it on or off in the menu the screen or the evf continue showing me the blown up highlights anyway. Am I missing something ir is it a bug?
but only at f1.6, but i like the flares.
@pilpop Great video! Forgot I was watching for stupid GH problems and just enjoyed! It's amazing the difference in the SLR and the Voightlander. I have the SLR so I can spot it in a sec.
I really like the built in time lapse controller. I made my first time lapse in no time. I used it with the electronic shutter function which will save the mechanical shutter from wearing out early ifd you are a heavy time lapse photographer.
I just made a 300 pics time lapse, 5 sec interval on full automatic. Unfortunately I made it in 4:3 format which was a slight let down.
GH3: video"isch" - no cinematic!? why? Aliasing!
Color Grading :(((
Sony A77 IQ
help Vitaliy and Nick
Little vid by me
You fellows mentioning eyepiece blur-- do you know about the small adjustment dial on the upper right side of the eyepiece that focuses the display image?
I received mine and it was a tad blurry on the edges, but upon adjusting the focus of the eyepiece, it is razor-sharp from every side--
@Greek_m43 It also means that you want to set a setting like WB or ISO after it goes into this lame "sleep" mode you have to push the button twice. Once to "wake" it up, and once to access the setting.
I don't see any reason for this behavior at all. If you don't want the info there, just press the bloody disp button. I'm actually surprised I haven't seen any more reactions on this...(maybe I'm still missing something? Went through all the settings several times...)
@AndersM I'm really annoyed with that too and need a fix.
@ChrisPeters: The Battery holds 4 Hours and needs a little bit more than 3 Hours to charge. When you use 1 Charger and 3 Batteries and if you can charge the Batteries one Day before, you should be fine. Use the first Battery, then use the second as you load Battery 1. Then you Change to Battery 3 and in the meantime load Bat. 2. If you can not load the Batteries before, ok, then maybe you should think about 2 Chargers. But even then, theoreticly 2-3 Batteries and 1 Charger should be ok.
