Do not count on ProRes or any other intermediate friendly wrapper or anything close to a visually transparent compression codec. It will probably be AVCHD 2.0 like Sony's consumer 4k camcorders and be a bitch to edit on anything but a supercharged computer. At CES the Panasonic reps were talking about a ~200 Mbps @ 2160p long GOP mode (that will more than likely equate to a ~100 Mbps 1080 All-Intra setting). 24 and 30 fps, but not 60 fps (except for 720 and 1080 modes). Possibly a 120 fps mode at 1080.
Mixed info. on whether it will be 8 bit or 10 bit optimized video with 4:2:2 sampling (Sony's $5,500 portable, bare-bones ENG broadcast camera has 10 bit, but the GH4k is supposed to street at $2,000 or under). Probably clean 1080p via HDMI 2.0 out, but not clean 2160p while recording.
You'll also need a new breed of ultra-fast SD cards being introduced at the same time. Uber expensive, as in the hundreds of dollars, in order to record 2160p and quite possibly for higher frame rate 1080.
The big questions are whether Panasonic's newer in-house sensors will lessen the appearance of moire and aliasing and if the jell-o cam effect is less pronounced. Again, a global shutter at this price point probably won't show up for a few years. Gotta have something for the pro models.
This will not meet the new ITU broadcast standards for UHD because that requires the much wider Rec. 2020 color spacing and other high end features that were just recently unveiled. There was only one expensive UHD TV at CES that met about 80% of the new standards, and that was from Vizio of all brands.
If 4k is your thing, you may want to save your pennies and see if a pure-video cam with more edit friendly codec and higher specs. would be a better choice. There are a number of other prosumer 4k models being introduced in 2014.
Rec 2020 is so hard that no manufactures are going to use it for a long time. It includes 4k 120Hz and new wider colors space.
I dont think that GH4 would need so fancy mem cards. Sandisk 95MBs is already widespread and I think it is enough for 200Mbs recording. 95MBs is after all 760Mbs.
GH4 sensor is according to rumors so fast that rolling shutter will be very mild. Nikon V1 has already very fast sensor which has practically no RS in video.
@Vesku Actually, the reps were stressing that the newer high speed cards were a >requirement< for 2160p recording. These super-speedy cards are also necessary on the various consumer 4k models from Sony, JVC, and others if you wish to record at that resolution. It may be the type of file structure or formatting of the card rather than the speed that might makes these types necessary.
That makes sense since you are quadrupling the pixel density of 1080 and even the Sandisk Extreme Pros could sometimes choke on the All-Intra 1080p hacks found right here.
The cards never reach their theoretical limits anyway and are always over spec'd.
Another known fact is that Panasonic will have optional XLR and SDI plug in units available (price TBD), which will again beg the question of whether after kluging together a franken-rig, a regular 4k video camera might be the smarter choice unless you must have interchangeable lenses.
"...unless you must have interchangeable lenses."
I must.
@Vesku, the GH4K is hardly a consumer camera at its price and specs level. It is more a hardcore hobbyist / semi-pro / professional / indie level camera.
The "GH5" however will be a consumer level camera (as the GH4K is not the GH3 successor, but the "GH5" will be).
Whatever but not a pro camera. It comes from their consumer department. GH3 was introduced as semipro but build quality is so weak that I dont agree. Mine is broken in many ways :)
How did you break your GH3?
With Panasonic stating they want the GH4k in the $2,000 and under range, and given the price-point/features of competing "4k" prosumer gear, I believe that this could still be considered well within the "consumer-grade" sphere of products. That is, until 4k takes hold and you can get a 2160p palm-camcorder for $200 at Walmart.
The most base level 4k camera with 10 bit 4:2:2 video capture is currently from Sony and it streets for $5,500. Sony considers that model a semi-pro ENG cam.
Unless Panasonic intends to shock the electronics world with an interchangeable 4k camera that meets or beats the features/quality of the BlackMagic Designs 4k Cinema Camera at half the price, I would imagine the GH4k will be severely gimped in some fashion so it doesn't compete with Panasonic's professional 4k gear. Canon does this all the time.
You kinda already can, as there is already cellphones which do "4K". Makes we wonder how long until we see this in a stand alone device for only a few hundred.
Last rumors in 43rumors:
http://www.43rumors.com/ft5-g-4k-has-focus-peaking-no-avchd/
So, no need for an external recorder for 422 color?
120fps very smart
To put it in staple words of that Gucci Mane character - well damn.
Closed to make it one single topic, plus announcement this week anyway
http://www.personal-view.com/talks/discussion/9542/gh4-aka-gh5-4k-video-camera
