Panasonic GH1 - Film Mode Settings
  • 114 Replies sorted by
  • @Mark_the_Harp
    "...I dug my Optex anamorphic out yesterday and had a go with it - it does seem to flare in uncontrolled lighting."
    Thanks for the tip on Cinefoil, I've ordered some to try it out. The Optex 1.33X anamorphic lens uses the same glass as the Century Optics adapter, but the Optex's mechanical design lacks any provision for attaching a lens hood. I modified mine by removing the dysfunctional outer front ring. This allowed me to press-fit the plastic mounting ring of a 72mm collapsible rubber lens hood around the exposed front anamorphic lens mount. It fit perfectly. To give the lens orientation lock screw a good grip on the front element, I cut a narrow circular strip from a rubber lens focus ring I scavenged off an old broken lens. I stretched this around the base of the front lens like a wide rubber band. As you can see from the bottom photo, the 3-position rubber lens hood pops securely into place around its plastic lens mount, and can be adjusted to provide as much shading as needed.
    The other trick with the Optex and Century Optic anamorphic adapters is to remove the rear lens element and reassemble it facing backwards. This produces a sharper anamorphic image for closeup shots, but puts distant objects out of focus.
    960 x 720 - 212K
  • Ingenious! By the way, you can also stamp / cut shapes out of a bit of cinefoil to get shaped bokeh highlights. A lot of fun to be had there!
  • I think it's very amusing that MrAnthony repeatedly and completely ignores the videos and explanations posted here, which indicate what the producer whants to say, which is, that the flat picture style is the only way to fit more dynamic range into the picture, which can then be taken into color correction. if you dont want to colorcorrect- dont use flat picture style, mranthony. :) But he, and many others want to- and so the flat option would be a blessing to improve GH2s small dynamic range, compared to film.
    that is the "film look"-part. the dynamic range. period.
  • As it can be seen, I already stopped any discussion of this topic, especially when there is just not any development about this primary matter, and even some people pull it retrogressively back...
  • A flat style is not the same as actual dynamic range. Duh.
  • Well I'm new here, GH1 shooter. Design school grad film major 8 yrs in the industry. 30 yrs of age from New Zealand. I shoot on full M, smooth flat as possible, FD, Panasonic, zeiss glass, fast and wide. I love my HGH1 Thanks Vitaliy and other contributors. I'm happy with results outdoors, lots of light, I have my own aesthetic tastes thats all i care about it really depends on what your doing. personally I've had way too many nights, weeks, months years, in post. Very minimal post with GH1 due to limits is great means I'm shooting more, concentrating on getting what I need to tell my story. Properly exposed shots enough light right time of day great scenes, equals easy post. Again it really depends on what your doing. Know your gear, post and sound. I dont mean adding a track off your iPod. If your in Sydney and like what you've read, let's have coffee.
  • 'I am awaiting the day most people owning the HDSLRs start shooting something worth looking at.' -VK
    True. Very True. Content.. I just got a gh1, so i'm seeing what it can do. As far as film modes go, it is paramount that you use different ones for different situations. I have found that the approach that emphasizes taking the sharpness down to -2 no matter the situation is not a very good one. dynamic range is an analogous concern: in darker situations it becomes important if it isn't lit very well (although stopping down with decent lighting makes it somewhat less important)... I have found that dynamic mode bleeds the color a bit while adding contrast. nostalgic is seemingly the most flat and brightest of them all and has a fairly bland color response (it's a step past smooth in all these ways), standard is fairly self explanatory, nature seems to have better contrast than smooth and nostalgic and also has a balanced color response.
    In using smooth with -2 sharpness for a while, as many testers have recommended as a must, I have found it negates the purpose of getting the sharpest lenses around because of the inherent limits of the format-mainly in comparison to medium and large format cameras, which are much less worried with sharpness due to the effective area of exposure (size of the picture). Also it may well be making the processor work harder with digital filtering and the like, by altering sharpness in film modes... So leaving the sharpness alone instantly cured a concern with clarity that i had using smooth or nostalgic modes.
    I think it's a worthy topic to test at length the characteristics of the film modes because just in an hour or so I found that it significantly alters the characteristics of the image to the point of even a 1/2 to full F-stop compared from nostalgic to dynamic. Of course I haven't looked at the manual regarding modes either, but I doubt it says much.
  • as far as the 5d goes, it does better in darker situations (just about anyone would agree) than most dslr's, the gh1 I love for its lens versatility (try using a PL lens ((usually equated with cinema lenses) on a 5d)) and also for its clarity... filmic smoothness can always be achieved with astute color correction and processing. The most film like dslr I've seen is the Nikon D90--looks like 16 or 8mm film to the T... The D90 only shoots in 720p at actual TRUE 24 frames per second, not 23.976.... which makes it perhaps the most unusual dslr video camera of the last few decades to my mind... In natural low light it has a grain that is totally unlike any other digital camera out there.... but for good old fashioned dslr video at full 1080 HD I like the gh1 (I don't like the smaller/more fragile build of the gh2 and I wasn't that into its image for some odd reason though I've seen some good things from it, to be sure).
  • Spend a little time to solve problems with colors on GH1. In most I don't like the Red color on it because it's almost orange. Only in RAW photos true Red colors. Simple example: Video image
    RAW image
    In the beginning i tried to fix it with Film Modes. On vectorscope they look almost same, but Vibrant -2 0 0 0 mode is little more close to RAW than others. So i took Vibrant as start point. Then i did use Channel Blend plugin in Sony Vegas to change color tones and shift them in RAW colors. Here is settings i get: First variation image
    Second variation, with brighter greens, and more close to RAW i think image
    Also you need to correct levels, after all this let's see the result: Video, did shot this with saturation +2 image
    Video, this one i desaturated in post image
    RAW image
    1920 x 1080 - 451K
    1920 x 1080 - 750K
    620 x 349 - 72K
    618 x 352 - 75K
    1920 x 1080 - 646K
    1920 x 1080 - 644K
  • @humpman, nice work. I really have given up on such a thing but you did a great job of getting there. Just goes to show that with hard work you can still dig out even more image quality from this camera.
  • @Aria thanks for response, i don't know how much people still seriously use GH1, but i believe they exist. Also there is new patched firmware for it http://www.personal-view.com/talks/discussion/8601/panasonic-gh1-firmware-research-testing#Item_15
  • @humpman, I still use my GH1 every week and have been for years shooting local TV shows and events. Nothing amazing but it does the job. I just can't use it to shoot landscapes of thick foliage in day light. It locks up the camera every time. If there's a bush swaying in the background it can put the fear of God in me. So I have other cameras like my G5's that I use for that stuff. The G5 is a pretty good camera if you use manual lenses. The GH1 has more dynamic range but the G5 can shoot with no issues in wide angle landscapes.
  • @humpman your findings on the film mode and Sony Vegas processing are very interesting! Is there any chance to closely replicate RAW colors using combinations of film mode and build in WB correction for GH1?
  • @yskunto in the beginning i tried to solve it with only Film Modes and WB correction, but results was pretty poor, i wasn't pleased by results.
