I do understand why PAL and NTSC exists, but what I do not understand why there are so many limitations with cameras. Perhaps you can enlighten me? 1) The Sony F3, a $16K camera, can't switch PAL/NTSC. What's so hard about it that they have two models? Marketing reasons? 2) Often you can't use the same memory card; if you record PAL you need to reformat to record NTSC.
What I don't understand... framerate is just something digital, so why can't we set framerate incrementally by frame? Is it more hard for a manufacturer to deliver 22 fps than say 24p? Ofcourse I do understand that you have a max framerate because of the chip / recording format. If the reason is they want to keep within official specifications, then why official specifications only have a few framerate options?
