Well, this idea with one clear filter is cool, but maybe this manta guy has not ran into problem with flange distance? I remember that our discussion was pretty much hypothetical. Maybe the deviation is small enough so it could be ignored?
You're right, we did :)
I think a spinning wheel with real ND's would be better than a single removable variable ND tho. Three ND's and one clear (so the flange distance won't change). It would be big, but I believe it would be a lot better for you finished image to use real ND's.
I hope he makes one m4/3-4/3. That way we can add any adapter we want.
http://www.personal-view.com/talks/discussion/1859/adapter-with-adjustable-nd-filter/p1
http://www.personal-view.com/talks/discussion/4525/m43-to-nikon-g-adapter-with-built-in-nds/p1
I know we were talking about this before!
Great thing.
this thing is AWESOME
I thought it to be interesting. I myself will be using the Xume adapters with Tiffen Water White 77mm ND's once my BMCC MFT arrives..
Good idea. I wonder what the optical quality of the glass will be. Might need a little ergonomic refining, but could still be a great solution for run'n gun work.
