Hello,
I am working on a project in FCPX where I constantly need to reverse, speed up, and slow down my clips. I basically want to be able to change "time" in the way you can do this when you scrub back and forth through video. Or the way a dj uses a turn table.
Is this possible, if so how?
Thanks so so much
You know about the Retime command, right? To change timing of the output, select the clip and use the Retime button or press Command-R. If you need to do several operations on the same clip or a portion of it, you can duplicate the clip or use the blade tool to cut it in pieces.
