Camera is equipped with two improved 1/2-inch sensors. On opposite sides of the body are lenses with a focal length of 6.7 mm (35 mm equivalent). ISO sensitivity range is 100-3200.
It allows recording of circular panoramas in format up to 5.7K with a resolution of 5760 × 2880 pixels and 30/25/24 fps.
In single lens mode, you can create 4K movies at a resolution of 3840 × 2160 pixels. Photo resolution can be up to 72 million pixels (11968 × 5984 dots).
The first-person view allows you to shoot wide-angle shots - like on an action camera. The FlowState system ensures smooth footage when using the camera in any environment.
In the arsenal of Insta360 X3 there is a 6-axis gyroscope, Wi-Fi 802.11a/b/g/n/ac and Bluetooth 5.0 wireless adapters, a 2.29-inch display, a USB Type-C port. The device can dive under water to a depth of 10 meters. The operating temperature range extends from -20 to +40 degrees Celsius. Dimensions are 114.0 × 46.0 × 33.1 mm, weight - 180 g. The battery with a capacity of 1800 mAh is responsible for power. The new one costs $449.99.
