Sony IMX477 based Raspberry Pi Camera
  • 8 Replies sorted by
  • The IMX477 spec sheet says that it can output 10 and 12 bit RAW video. I wonder whether this will be supported with this camera module and the Raspberry Pi?
  • FREE PDF Raspberry Pi Camera Guide
    Take pictures and shoot video with your Raspberry Pi. Connecting a High Quality Camera or Camera Module turns your favourite credit-card-sized computer into a powerful digital camera. Learn how to set up and control the camera to capture stills and video footage. Discover the numerous modes and effects available, and use the camera in a variety of exciting projects across 17 packed chapters:
    Set up the new High Quality Camera, attach a lens, and start capturing stunning hi-res images
    Take selfies and shoot stop-motion videos
    Build a wildlife camera and also an underwater one
    Make a smart door with a video doorbell
    Set up a security camera to monitor your home
    And much, much more!
    https://magpi.raspberrypi.org/books/camera-guide
  • wow....way too much coronashxt made me totally miss this. Now imagine if next, they make a 16mm version ! Then we won't need camera companies. Can you run a raspberry off a powerbank ? ...short answer " Yes, most (but not all!) USB power banks are capable of powering a Raspberry Pi, since they usually have an output voltage of 5 V. And yes, by using a (quite large) 50 Ah power bank, you can definitely expect your Pi to run for at least 24 h. See the long answer below for reasoning and further relevant aspects"
  • You need 5V and a minimum of 3A to power the Raspberry Pi 4. Not many power banks do that. The Raspberry Pi 4 also needs cooling, since it heats up and throttles. Fans, heatsinks etc.
  • So, here's my rig with a $25 CCTV C lens (Pixco 25mm C-Mount F1.4 C Mount):
    And here are two test pictures (compressed for upload):
    CA shows up, which is a (cheap) lens property. Time to mount a Zeiss..
    2042 x 3629 - 2M
    3042 x 2280 - 2M
    3975 x 2980 - 2M
