720p 60 workflow with flowmotion
  • i shoot in720p because i do alot of slo mo in post. i edit and render in progressive then i author and burn my dvd and sometimes a blu ray. i use sony vegas 12. i use nero 10 for dvd authoring. im getting terrible slo mo even just going down to 50%. im getting better results shooting in 1080i. i believe it is a workflow issue and not the patch but any insight is appreciated.. thanx
  • 5 Replies sorted by
  • Disable 'smart resample' in Vegas. Slow down to 1/ 2.5 = 40% if you render in 24p. Use shutter speed of 1/125sec to come close to 180degree.
    If you need more flexibility try twixtor plugin and use higher shutter speed.
  • first off thank you for your reply. but why would i render to 24p if its 780p and lastly should i render to progressive or interlaced if my burn is dvd
  • your post reads like i need to slo down my 780p footage to 40% and render the whole project as 24p. i dont understand that. thanks so much for helping me
  • disabled smart resample on every clip. no joy. i dont get it
  • I think you mix up frame rate with Resolution. 24/60 = 1/2.5 = 40%.
    Please look also at following topics: http://www.personal-view.com/talks/discussion/1210/slo-mo-in-1080/p1
    Especially http://eugenia.queru.com/2009/02/09/butter-smooth-slow-motion/ should be helpful.
