Panasonic GH3 color temperature shift after recording. Please help!
  • I did a shoot at the Ripley's Aquarium in Toronto, Ontario today and ran into a weird problem. When I hit record 3-4 frames of video would be my desired white balance and then it would shift a few thousand degrees warmer without changing anything. It did this on a few clips but not all of them. Has anyone experienced this before? I will upload a few examples shortly.
  • 4 Replies sorted by
  • would help if you share your settings
  • @tylerknight That's one of the most bizarre things I've ever seen! Never experienced that before...
  • @MRfanny this was shot with the ALL-I 72mbps MOV format on standard with 0's through the board. Custom white balance on each shot.
    @jonpais Isn't it?! I haven't seen this come up anywhere before and it isn't major as it's only a few frames at the start but the issue is that I set it for the white balance at the start and it shifts warmer.
