Zoom H5 recorder
    • Modular Mic and Input System
    • Includes XY Microphone Module
    • Four Simultaneous Inputs
    • Uses SD Memory Cards
    • Compatible with H6 Mic Modules
    Not available yet at :-)
    http://www.bhphotovideo.com/c/product/1026852-REG/zoom_h5_handy_recorder.html
    419 x 539 - 32K
  • 2 Replies sorted by
  • Officially introduced
    • System of interchangeable input capsules — Compatible with all Zoom input capsules
    • Includes detachable X/Y capsule (XYH-5) with extended signal capacity and shockmounted mics for reduced handling noise
    • Four-track simultaneous recording
    • Large backlit LCD display
    • Records directly to SD and SDHC cards up to 32GB
    • Up to 24-bit/96kHz audio in BWF-compliant WAV or a variety of MP3 formats
    • Two mic/line inputs with XLR/TRS combo connectors each with selectable phantom power and -20dB pad
    • Analog-style gain controls for each input
    • Protective “roll-bar” type covers prevent accidental movement of gain controls
    • Plug-in power (2.5 volts)
    • Built-in effects, including low-cut filtering, compression and limiting
    • Chromatic tuner and metronome
    • Auto-record, Pre-record and Backup-record functions mean that you’ll never miss that perfect take
    • MS decoding
    • Multitrack to stereo internal mixdown
    • Normalize, Divide and Trim editing
    • Voice memo and up to 99 marks per recording
    • A/B loop playback
    • Variable playback speed and variable pitch without affecting playback speed
    • Multichannel and stereo USB audio interface for PC/Mac/iPad with loop back function
    • Mountable directly to DSLR or camcorder with optional HS-01 Hot Shoe Mount adapter
    • Uses two standard AA alkaline or NiMH rechargeable batteries
    • Over 15 hours of claimed operation with alkaline batteries
    Expected price is $269, will be available in June.
