Just purchased a secondhand GF3 that I will be using for aerial photography. Need to add a remote trigger function. Before I go down the route of having a micro servo physically pressing the trigger button, I would like to see if these software modifications offer intervalometer functionality. Tried searching but could not find anything.
Huh. Don't you think it is best to get one of latest Wi-Fi equipped cameras so you'll see that you are shooting and will be able to shot remotely?
Well, I chose to go with the GF3 due to those being available second hand at reasonable prices, the risks with aerial photography are obvious and I dont want to risk breaking expensive cameras just yet. A crash with a GF3 is not the end of the world. Also, the camera not having wifi is a + with regards to possible sources of radio interference, the TX/RX operating in the same 2.4 GHz band (using 5.8 GHz for FPV).
So, back to my original question. Is it possible to add intervalometer functionality to the GF3?
I have 2 systems... both works flawlessly with GH2/GH1/GX1 and should be also w GF3: be sure to get the right connectioncable/plug! Check connectability! http://www.pixelhk.com/Proshow.aspx?id=299 http://www.ebay.de/itm/JY-710-P1-Wireless-Timer-Remote-Cord-For-Panasonic-FZ150-FZ200-GX1-G5-G3-GH1-GH3-/271270426350?pt=Camera_Camcorder_Remotes&hash=item3f28fa36ee google or ebay will give you more options... have fun / Kurt
Thanks, but the GF3 does not have any connection for external intervalometers, only the G3/GH3 have that. Panasonic removed the port on the GF series after GF1, external intervalometers can only be used on the first GF series camera body. I was hoping the Ptool software would add intervalometer functionality to the camersa in the same way as CHDK does on my current Canon S95. If that is not possible, then I will build a mechanical remote trigger: http://www.flickr.com/photos/hamishfenton/8062988138/
Sorry.... I did not check if the GF3 has a connection!! Too bad!
