TICO compression is visually lossless light compression specifically designed for the industry. It is is extremely tiny in hardware (FPGA, ASIC) , fast and powerful in software (CPU), robust for real-time operation with no latency.
Up to now, image and video are sent or stored uncompressed into many displays and systems such as cameras videos servers or recorders. TICO is a smart upgrade path to manage higher resolutions (4K, 8K…) and frame rates while assuring visual quality, keeping power and bandwidth at a reasonable budget and reducing significantly the complexity and cost of the system.
TICO compression key features
- Visually Lossless quality between 2:1 and 4:1.
- Persistent and Robust: Indistinguishable image loss over multiple generations
- Latency: Few Microseconds – very few line of pixels ( selectable from 1 to x)
- Small complexity and ultra-compact codec: easy to implement in low-cost FPGA or ASIC. It uses little internal memory and no external memory.
- Powerful , Real-time or faster than real-time in CPU
- Compatible with different resolutions, from mobile to 4K/8K UHDTV, via multiple usual transport schemes.
- Designed to be a standard for the industry-wide support: TICO compression technology is available on multiple software and hardware technologies.
- Code, hardware IP-cores and software libraries are licensable from intoPIX.
Via: http://www.intopix.com/products/index/index/id/31/lang/en#.UjC6vcanpHQ
