Sound Devices 664 Field Production Mixer
    • The 664 has six ultra-low noise, high-dynamic-range analog inputs.
    • The 664 can send its main left/right outputs to three cameras simultaneously.
    • The 664 can record each of its inputs and its four output buses, for 10 record tracks. Recordings are saved to CompactFlash and SD cards. Recordings are either 16- or 24-bit Broadcast WAV files with extensive metadata.
    • With the mixer's built-in, rock-steady Ambient time code generator, multiple devices can operate in synchronization.
    See more - http://www.sounddevices.com/products/664/key-features/
  • 1 Reply sorted by
  • You forgot to mention cost... $4,000 :-).... of course, if you have the money, I'm sure it is worth it!! Sound Devices makes fabulous gear!
