35mm F1.8 Panasonic LUMIX S Prime Lens
    352 x 496 - 17K
    598 x 612 - 38K
    493 x 468 - 19K
    564 x 752 - 47K
  • 10 Replies sorted by
  • Announcement poster
    388 x 543 - 23K
  • Photo, scheme and MTF
    640 x 856 - 47K
    681 x 513 - 34K
    678 x 547 - 28K
  • Uk PR
    Panasonic Introduces New LUMIX S 35mm Wide-Angle Fixed Focal Length Lens with F1.8 Large Aperture
    Compact, Lightweight LUMIX S 35mm F1.8 (S-S35) for the LUMIX S Series
    Panasonic is pleased to announce a new large-aperture wide fixed focal length lens, the LUMIX S 35mm F1.8 (S-S35).
    The LUMIX S 35mm F1.8 comes as the fourth addition to the series of four fixed focal length, large-aperture F1.8 lenses based on the L-Mount system standard: 85mm (S-S85), 50mm (S-S50), 24mm (S-S24) and the new 35mm (S-S35). These lenses feature a common size and position of control parts to provide practical advantages in use, and the centre of gravity of these lenses is almost the same so that it is easy to exchange lenses quickly with minimum balance adjustment when the camera is on a gimbal. Common filters can also be used thanks to the same diameter, and the descriptive performance of these lenses is also consistent.
    The LUMIX S 35mm F1.8 is comprised of eleven lens elements in nine groups including three aspherical lenses and three ED (Extra-Low Dispersion) lenses. The use of three aspherical lenses realises both high descriptive performance and beautiful bokeh, which are common advantages to the series of all F1.8 lenses. The ED lenses effectively suppress chromatic aberration. The lens can be used for versatile situations including landscapes and snapshots, taking advantage of the natural angle of view, as well as portrait. It can also be used for close-up shots as a result of the minimum focusing distance of 0.24m.
    The LUMIX S 35mm F1.8 is capable of smooth, silent operation to work with the camera’s AF system with the sensor drive at max.240 fps. For the non-linear setting, focus is shifted with a variable amount according to the rotation speed of the focus ring while focus is shifted with a designated amount according to the rotational quantum of the focus ring for the linear setting. Sensitivity (the amount of focus shift per rotational quantum) can be selected from 90 to 360 degrees by 30 degrees to enable intended focus operation. The LUMIX S 35mm F1.8 also excels in video recording performance with a mechanism that suppresses focus breathing, which was a fatal problem of all interchangeable lenses designed for still image photography. Together with a micro-step aperture control for smooth exposure change, professional quality video can be recorded.
    With its approximately 295g compact size and light weight, the LUMIX S 35mm F1.8 features stunning mobility to fit the S5, LUMIX’s smallest full-frame model. The rugged dust/splash-resistant*1 design withstands use under harsh conditions even at 10 degrees Celsius below zero. The filter diameter is 67 mm, with a 9-blade circular aperture diaphragm.
    The LUMIX S 35mm F1.8 will be available from mid-November at RRP £579.99 (IRE €659.99).
    To further strengthen the S-Series lens system, development is underway for a new 18 mm ultra-wide angle fixed focal length lens with F1.8 large aperture. Alongside the development of new lenses, firmware update programs2 are also available for the conventional S-R70200, S-E70200, S-R70300 and S-R24105 lenses to improve the stability of Image Stabiliser during video recording. In addition, image stabilisation performance of Dual I.S. 2 has been increased from 6.5 stops to 7.5 stops3 for photoshoots when the S-R24105 is mounted on the LUMIX S1H, S1R or S1.
    Panasonic and L-Mount system alliance is committed to further expansion of the L-Mount lens line-up, as well as the enhancement of performance, to fulfil the needs and maximise satisfaction of customers.
    The LUMIX S-S35 is a qualifying product for the LUMIX PRO program. The LUMIX PRO program is designed to support LUMIX users when they need it the most, with a range of benefits available to members not only in their own countries but also in countries that they visit for work.
    Check out http://www.lumix-pro.com for details and Terms & Conditions, on eligible levels, countries, and products.
    791 x 590 - 61K
    792 x 594 - 61K
    796 x 335 - 52K
    786 x 590 - 80K
