Yongnuo YN455 m43 camera
    • 20 million pixels m43 sensor
    • Snapdragon SoC main SLI, CPU 8 cores 2.2GHz
    • 6GB RAM
    • 64GB storage
    • up to 256GB memory card compatible (Micro SD)
    • 2/3 / 4G network compatible (Nano-SIM)
    • 8 million pixel front camera
    • 5.0-inch tilt touch monitor
    • 4K 30p recording
    • 3.5mm headphone jack
    • 3.5mm microphone jack
    • Dual USB-C port (maximum 1080p output on the side, OTG compatible on the bottom)
    • 2.4 / 5GHz Wi-Fi compatible
    • Bluetooth 5.0 compatible
    • GPS
    • Equipped with LED light
    • 162 x 85 x 56 mm
    • 670g
    • 4400mAh battery
    • 18W PD / QC3 fast charging compatible
    • Prices:
      • Body: 3888 yuan (about 66,000 yen in Japanese yen)
      • 25mm F1.7 kit: 4487 yuan
      • 42.5mm F1.7 kit: 4686 yuan
    684 x 453 - 41K
  • 7 Replies sorted by
    800 x 506 - 43K
    792 x 796 - 106K
    800 x 548 - 38K
    800 x 428 - 45K
    631 x 905 - 91K
    735 x 872 - 91K
  • For $600 I'm guessing this will provide a decent image?
  • So if it accepts sim cards I can make phone calls with it?
  • I did a quick interview with them at CP+2018 (or maybe 2019) when they had a similar prototype which was using a EF mount (still M4/3rd sensor). They had intended it to be a phone as well, but did not yet have the necessary license at that time. The major physical differences on this version other than the mount seem to be the deep grip, and tilting screen.
  • @DrDave
    "For $600 I'm guessing this will provide a decent image?"
    Decent is relevant, and ultimately depends on which M4/3rd sensor they are using among other things. With its Ai and Compared to other android devices using the same type of Ai it has the potential to be relatively exceptional photo and video quality due to the larger sensor.
    800 x 280 - 34K
  • On a gimbal this might pair up nice with https://vdo.ninja/
