Laowa 1.33x Anamorphic Adapter
  • 2 Replies sorted by
  • It can be used on a number of cinema lenses besides the OOOM 25-100 listed below. For those with more expensive cinema lenses who want to add nondescript flaring and distortion to the bokeh, it may be a way to take the edge off of a sharp, contrasty pro cinema lenses and give it more of a vintage look. As compared to real anamorphic cinema lenses or front anamorphic adapters, it had some advantages and disadvantages.
    Disadvantage
    1. No oval bokeh.
    2. Does not add the classic anamorphic streaking lens flares.
    3. Does not stretch as wide as a regular anamorphic lens.
    Avantages
    1. It does not add breathing to the lens, where most less expensive anamorphic lenses breath.
    2. Less bulky than front anamorphic adapters.
    3. Can work with wide angle lens, that may not work so well with front anamorphic adapters.
    4. Inexpensive compared to other rear PL anamorphic adapters.
    List of compatible lenses with Laowa 1.33x Rear Anamorphic Adapter
    • The PL mount plate may need to be removed for some lenses
    Angenieux 28-340mm Optimo Zoom T3.2
    Angenieux 24-290mm Optimo Zoom T2.8
    Angenieux Optimo Style 16-40mm T2.8 Zoom
    Angenieux Optimo Style 30-76mm T2.8 Zoom
    Carl Zeiss Supreme Prime 25 mm T1.5
    Carl Zeiss Supreme Prime 29 mm T1.5
    Carl Zeiss Supreme Prime 35 mm T1.5
    Carl Zeiss Supreme Prime 50 mm T1.5
    Carl Zeiss Supreme Prime 85 mm T1.5
    Carl Zeiss Compact Prime 15mm T2.9
    Carl Zeiss Compact Prime 18 mm T2.9
    Carl Zeiss Compact Prime 25 mm T2.1
    Carl Zeiss Compact Prime 28 mm T2.1
    Carl Zeiss Compact Prime 35 mm T2.1
    Carl Zeiss Compact Prime 50 mm T2.1
    Carl Zeiss Compact Prime 85 mm T2.1
    ARRI 18-80mm Alura Studio Zoom T2.6
    ARRI 45-250MM T2.6
  • Why call if anamorphic ?
