A new company called Metalenz, which emerged from stealth mode, is looking to disrupt smartphone cameras with a single, flat lens system that utilizes a technology called optical metasurfaces. A camera built around this new lens tech can produce an image of the same if not better quality as traditional lenses, collect more light for brighter photos, and can even enable new forms of sensing in phones, all while taking up less space.
Instead of using plastic and glass lens elements stacked over an image sensor, Metalenz's design uses a single lens built on a glass wafer that is between 1x1 to 3x3 millimeter in size. Look very closely under a microscope and you'll see nanostructures measuring one-thousandth the width of a human hair. Those nanostructures bend light rays in a way that corrects for many of the shortcomings of single-lens camera systems.
The core technology was formed through a decade of research when cofounder and CEO Robert Devlin was working on his PhD at Harvard University with acclaimed physicist and Metalenz cofounder Federico Capasso. The company was spun out of the research group in 2017.
Light passes through these patterned nanostructures, which look like millions of circles with differing diameters at the microscopic level. “Much in the way that a curved lens speeds up and slows down light to bend it, each one of these allows us to do the same thing, so we can bend and shape light just by changing the diameters of these circles,” Devlin says.
The resulting image quality is just as sharp as what you'd get from a multilens system, and the nanostructures do the job of reducing or eliminating many of the image-degrading aberrations common to traditional cameras. And the design doesn't just conserve space. Devlin says a Metalenz camera can deliver more light back to the image sensor, allowing for brighter and sharper images than what you'd get with traditional lens elements.
