85mm F1.8 LUMIX S Lens
    • 9 elements in 8 groups (2 ED lenses)
    • 9 diaphragm blades
    • Circular aperture diaphragm
    • Min Aperture F22
    • Min Focus Distance - 0.8m
    • 67mm Filters
    • 73.6mm x 82.0mm
    • Comes with lens cap, lens rear cap, lens hood
    • 355g
    694 x 559 - 65K
    778 x 650 - 65K
    797 x 342 - 35K
  • 12 Replies sorted by
  • The lens will be announced on November 5th. Here are the specs from Nokishita https://mobile.twitter.com/nokishita_c/status/1323138888227979266/photo/1
    1529 x 961 - 146K
  • Good weight. Excited about this new line of more affordable lenses
  • The upcoming Panasonic Lumix S 85mm f/1.8 lens will be officially announced on Nov. 5th. The US price for this lens will be $599. Here are the leaked images of the new Panasonic LUMIX S 85mm f/1.8 lens. Nokishita reports the price will be 81,400 yen including Yodobashi tax, 74,000 yen for Bic Camera Group, 73,260 yen for Kitamura, etc.
    https://mobile.twitter.com/nokishita_c/status/1323383723820154881 image image image image
    698 x 645 - 78K
    746 x 622 - 58K
    730 x 583 - 40K
    704 x 572 - 40K
  • UK PR
    Panasonic is pleased to introduce a new large-aperture medium-telephoto fixed focal length lens, the LUMIX S 85mm F1.8 (S-S85).
    Based on the L-Mount system for LUMIX S Series full-frame mirrorless cameras, the 85mm F1.8 is the first out of four F1.8 large-aperture lenses Panasonic has announced it will be releasing. These four F1.8 lenses feature common size and position of control parts to provide practical advantage in use. The same filters can also be used due to identical diameters.
    Comprising 9 elements in 8 groups, the use of 2 ED (Extra-low Dispersion) lenses effectively suppress both axial chromatic aberration and chromatic aberration of magnification. Panasonic S Series lenses pursue the beauty of bokeh and the LUMIX S 85mm F1.8 provides smooth defocus gradation from the focus peak to the neighbouring area of the image as well as smooth, round bokeh of point light source without vignetting. The LUMIX S 85mm F1.8 also excels in video recording performance with a mechanism that suppresses focus breathing. The filter diameter is 67 mm, with a 9-blade circular aperture diaphragm.
    With its compact 355g (approx.) of light weight, the LUMIX S 85mm F1.8 is incredibly flexible. The rugged dust/splash-resistant* design withstands use under harsh conditions even at 10 degrees below zero.
    The LUMIX S 85mm F1.8 will be available from the end November at RRP £599.99 (€679.99 Ireland).
    In addition to the four planned F1.8 large-aperture lenses, A 70-300mm telephoto zoom lens is also under development to further enhance LUMIX S Series lens line-up. Panasonic and L-Mount system alliance are committed to the development of L-Mount lenses for the further expansion of its line-up to fulfil the needs of customers.
  • US PR
    Panasonic is pleased to introduce a new large-aperture medium-telephoto fixed focal length lens, the LUMIX S 85mm F1.8 (S-S85) that enhances portrait photography with its beautiful bokeh effect. Based on the L-Mount system for the LUMIX S Series full-frame mirrorless camera, Panasonic is going to release four F1.8 large-aperture lenses as previously announced, and this 85mm F1.8 is the first one. These four F1.8 lenses feature common size and position of control parts to provide practical advantage in use, for example, when the camera is on a gimbal, it is easy to exchange lenses quickly with minimum adjustment of connected gears. Filters can also be used in common thanks to the same diameter. Boasting high mobility realized by its compact size and light weight, the LUMIX S 85mm F1.8 is also suitable for stills.
    Comprising 9 elements in 8 groups, the use of 2 ED (Extra-low Dispersion) lenses effectively suppresses both axial chromatic aberration and chromatic aberration of magnification. Panasonic S series lenses even pursue the beauty of bokeh and the LUMIX S 85mm F1.8 provides smooth defocus gradation from the focus peak to the neighboring area of the image as well as smooth, round bokeh of point light source without vignetting. The LUMIX S 85mm F1.8 also excels in video recording performance with a mechanism that suppresses focus breathing, which was a critical problem of all interchangeable lenses designed for still image photography.
    With its compact size and approximately 355g weight, the LUMIX S 85mm F1.8 features stunning mobility. The rugged dust/splash-resistant* design withstands use under harsh conditions even at 10 degrees below zero for high mobility. The filter diameter is 67 mm, with a 9-blade circular aperture diaphragm.
    In addition to the four F1.8 large-aperture lenses, A 70-300mm telephoto zoom lens is also under development to further enhance LUMIX S Series lens lineup. Panasonic and L-Mount system alliance are committed to the development of L-Mount lenses for the further expansion of its lineup to fulfill the needs of customers.
