645 FTT Fast Twin Tripod is the first model in a new range featuring double tubing and Ultra L-Lock lever technology for the most robust support ever. The tripod is provided with a 2 in 1 half ball: a standard 100mm bowl along with a 75mm adapter to enable the use of a wider range of video heads. It also features a middle spreader lock. However, the 3-angle selectors make the use of a spreader a matter of optional preference. Users will also enjoy the extremely low maintenance this product requires.
635 FST Single-Leg Fast has single tubing and features the Extra M-Lock twist lock, for secure locking with a single, easy gesture. The 635 FST tripod features a 75mm half ball and is compatible with a 60-mm half ball adapter (sold separately). In addition, it features Easy Link friction arm attachments compatible with Manfrotto anti-rotation and Arri anti-twist pins. This enables users to attach an external monitor or any other accessory they may require without the risk of the arm rotating while in use.
