The Video Electronics Standards Association (VESA®) today announced it has published version 1.4 of the DisplayPort (DP) audio/video standard. The first major update to DisplayPort since version 1.3 was released in September 2014, DP 1.4 is also the first DP standard to take advantage of VESA’s Display Stream Compression (DSC) technology. DSC version 1.2 transport enables up to 3:1 compression ratio and has been deemed, through VESA membership testing, to be visually lossless. Together with other new capabilities, this makes the latest version of DP ideally suited for implementation in high-end electronic products demanding premier sound and image quality.
DisplayPort is a packet-based, extensible protocol for transporting video and audio data. Initially introduced as a new external interface, its flexibility has enabled its adaptation to embedded displays and incorporation into other connectors like the new reversible USB Type-C™ interface and Thunderbolt™. Its Multi-Stream Transport (MST) capability enables high-resolution support of multiple monitors on a single display interface.
DP 1.4 further builds on the capabilities of the standard’s prior incarnations. The use of video transport compression enhances the ability to take advantage of the USB Type-C connector, enabling both high-definition video and SuperSpeed USB, while also facilitating High Dynamic Range (HDR) and 8K video across the DisplayPort or USB-C connector. Examples of increased display resolution with the new standard include 8Kp60Hz HDR deep color and 4Kp120Hz HDR deep color.
http://www.vesa.org/featured-articles/vesa-publishes-displayport-standard-version-1-4/
