sony-hack:image-structure
Firmware files package
It is a simple TAR in UStar format. Can be unpacked with any utility. The only problem i can imagine here is to repack it on windows since the package mentioned root as a user. This tar contains all the files of the firmware. The folder structure locks pretty the same for NEX and SLT firmware.
Root folders:
0100_config
0101_config_sum
0300_partconf
0301_partconf_sum
0630_cas
0631_cas_sum
0800_appli
0801_appli_sum
Full listing:
0100_config
  mount.conf 0.53 Kb
0101_config_sum
  config.sum 75 b
0300_partconf
  partinf.conf 1.65 Kb
0301_partconf_sum
  partconf.sum 77 b
0630_cas
  AS_1_0.APP 224.00 Kb
  CA_2_0.APP 448.00 Kb
0631_cas_sum
  cas.sum 150 b
0800_appli
  usr2
    data
      sound
      scenarios
        app_cwb_snr.esf 11.67 Kb
        app_rec_snr.esf 37.71 Kb
        app_uud_snr.esf 0.57 Kb
        app_eps_rsf.rsf 12.13 Mb
        app_repair_snr.esf 1.80 Kb
        app_movie_rec_snr.esf 14.98 Kb
        app_stg_snr.esf 33.87 Kb
        app_hdmi_snr.esf 474 b
        app_play_snr.esf 37.48 Kb
        app_dlg_snr.esf 2.30 Kb
        app_rhg_snr.esf 1.18 Kb
        app_dds_snr.esf 487 b
        app_usb_snr.esf 0.77 Kb
        app_top_snr.esf 7.99 Kb
        app_menu_snr.esf 5.80 Kb
      BEEPDATA.BIN 318.25 Kb
    boot
      initrd.img 1.32 Mb
      vmlinux.bin 1.29 Mb
      rootfs.img 1.29 Mb
    ex_conf_202.h 16.09 Kb
  avsys
    av.bin 3.04 Mb
    sa_srec.bin 0.98 Mb
    ancy_ipl.bin 10.40 Kb
    ancy.bin 0.64 Mb
  boot
    GPS
    factory
      Asys.bin 28.00 Kb
      initreg.bin 5.98 Kb
      Hsys.bin 8.00 Kb
      ex_cnf.bin 2.50 Kb
    cas
      CA_FROM.BIN 16.00 Kb
      CA_FRAM.BIN 3.75 Kb
      BRD.bin 0.90 Kb
    backup
  usr
    log
    bin
      app
        main.sh 1.04 Kb
        deviceInfo.xml 0.51 Kb
        main 16.31 Mb
        haif.ko 5.84 Kb
        serr.ko 5.58 Kb
        main3.sh 0.76 Kb
      mpr_monio 27.59 Kb
      debugio 1.19 Kb
      mpr_viewLog 21.83 Kb
      memtool 6.96 Kb
      sen 34.38 Kb
      usr_up 0.51 Kb
      testcmd 10.78 Kb
      debugio_core 4.07 Kb
      ud_datcnv 4.28 Kb
      av_conio 11.45 Kb
      up 4.81 Kb
    lib
      libadj30.so 14.91 Kb
      libpro00.so 26.20 Kb
      libadj33.so 16.02 Kb
      libwtle.so 319.74 Kb
      libSnr.so 7.88 Kb
      libosal.so 27.26 Kb
      libcmdcmm.so 31.96 Kb
      libadj36.so 2.68 Kb
      libBackupTable.so 325.12 Kb
      libusbcmd.so 10.91 Kb
      libul_debug.so 3.79 Kb
      libadj32.so 21.42 Kb
      libpro01.so 9.03 Kb
      libadj31.so 18.58 Kb
      libadj37.so 24.43 Kb
      libul_xml.so 44.62 Kb
      libpro11.so 20.87 Kb
      libBackupCore.so 42.93 Kb
      libusb.so 56.36 Kb
      libdebugprintf.so 2.25 Kb
      libgps.so 2.25 Kb
      libadj34.so 4.59 Kb
      libAppBackupApi.so 18.02 Kb
      libupdatercommon.so 33.90 Kb
      libsencore.so 114.58 Kb
      libitype.so 220.21 Kb
      libupdaterapi.so 97.59 Kb
      libAppSenserApi.so 60.16 Kb
0801_appli_sum
  appli.sum 7.64 Kb
sony-hack/image-structure.txt · Last modified: 2015/08/10 17:22 by vitaliy_kiselev
