samsung-hack:nx1-and-nx500-difference
Difference of NX1 and NX500
Some people think that the two cameras are identical and that NX500 is just software crippled, there actually are several hardware differences that we can observe:
  • Unordered List Item LSI (CPU + supporting hardware like ISP, HW codecs, etc) is different
  • RAM is different.
Both are more advanced in NX1.
LSI differences
NX1 NX500
cma: CMA: reserved 256 MiB at 96000000 cma: CMA: reserved 288 MiB at 94000000
cma: CMA: reserved 128 MiB at 8e000000 cma: CMA: reserved 72 MiB at 8f800000
Memory: 115000k/115000k available, 409288k reserved, 0K highmem Memory: 142828k/142828k available, 381460k reserved, 0K highmem
[arch/arm/mach-drime5/board-d5_nx1.c, fn:drime5_es_init, 3636] wm8962 [arch/arm/mach-drime5/board-d5_nx500.c, fn:drime5_es_init, 1745] nau8822
DRIME5: IDS : 26(ISP), 38(ARM) PROMISE : 87 RESULT : 6 DRIME5: IDS : 23(ISP), 35(ARM) PROMISE : 82 RESULT : 5
DRIME5 ASV : 6 Group DRIME5 ASV : 5 Group
VDD_ISP: 770 ←-1400 mV at 1030 mV VDD_ISP: 770 ←-1400 mV at 870 mV
Cores seem to be identical (from OS point of view) but LSI seem to be different with different parameters. Probably related to various IP blocks in SoC.
Memory
Although there is roughly the same amount of RAM available to Linux, NX1 has significantly more memory available to (presumably) RTOS portion as can be seen from st cap capmm show
NX1 has 1696 MB and NX500 has 704 MB. With the Linux OS taking ~200 MB it leaves ~1.5 GB for NX1 and 0.5 GB for NX500 which is in line with real world buffer performance. It is also possible that RAM is not running at the same speed between the two.
samsung-hack/nx1-and-nx500-difference.txt · Last modified: 2016/04/13 22:23 by vitaliy_kiselev
